MAF in 2000 4 runner
Old May 27, 2006 | 07:07 AM
need help's Avatar
Any help in replacing this? I have a 6 cyl and I am needing to replace the MAF. How difficult is it? Any help or tips would be great thanks.
Old May 27, 2006 | 07:18 AM
JHupp's Avatar
ahh, the good old mass air flow sensor, should be easy enough. It is located on the intake tube right after the air box. It kind of clips on to the intake tube. Just unclip, cut the wires, splice the wires into the new one, and clip back on. If you've done any type of electrical work, it should not be a problem. It might even just unplug, I don;t remember from doing mine, but it is easy nonetheless.
Old May 29, 2006 | 06:19 AM
GSGALLANT's Avatar
No cutting required if you're just replacing the MAF. Disconnect the electrical connector, remove the screws holding the sensor to the air intake tube, remove the old sensor, install the new sensor, re-install the screws, re-connect the electrical connector.
Old May 29, 2006 | 11:36 AM
fireteacher's Avatar
ditto....DO NOT CUT ANY WIRES!!!!!!!!
Old May 29, 2006 | 11:37 AM
i have a spare that i bought off of ebay used....i never put it on because i just cleaned it...50 bucks and its yours!
Jun 1, 2021 01:51 PM
mskalmus
May 28, 2017 07:51 AM
Avenged
Jul 9, 2015 07:55 AM
Cplmike
Jul 8, 2015 08:47 PM
Jnkml
Jul 6, 2015 01:20 PM
