Leaking fuel injector
Old Dec 5, 2010 | 01:10 PM
mlrtime99's Avatar
Finished my head gasket and MAN that thing idles like a champ. I had previously adjusted the idle screw to get it to idle around 700 rpm '91 3vze. Cranked it up after the rebuild and it's idling around 2000 rpm, guess I fixed something
Anyways intensive flashlight observation looking for leaking hoses anything of that nature and I can tell that one of the fuel injectors has a bad O ring at the top (between injector and rail) and drips once every 2 seconds. The good news is it instantly vaporizes as soon as it touches the top of the block. The bad news is it's fuel regardless. Screw mpg, is this going to blow up? After all this work I'm REALLY not in the mood to lift the plenum again. Am I just being a lazy ass?
On another note if I DO pull the plenum are the fuel rails pressurized when the key is ON so I can check them this time around? I can't recreate the leak when I have the key just set to ON so either the leak is vibration sensitive or there's no pressure without the engine running.
Old Dec 5, 2010 | 01:23 PM
rworegon's Avatar
Hey, it's fuel that leaking and very likely to get worse overtime.....the consequences...big orange flames. Fix it right with new O-rings and grommets on each injector.
On my 5vzfe I don't think the rails pressurized in the ON position....maybe I just did not leave it in the ON position long enough when re-doing the top end a few weeks ago..
Old Dec 5, 2010 | 01:40 PM
mlrtime99's Avatar
ya I went through the FSM and there's 2 pins to jump in the diagnostic port to power the fuel pump while the key is on.... I did get new O rings with the rebuild but no dice I guess. SIGHHHH ok time to pull it ALL apart one more time then I swear to god I'm just buying a motor swap.
Old Dec 5, 2010 | 01:51 PM
rworegon's Avatar
I missed that in the FSM on the pump - it would have been nice to know when I did mine. Did you put a bit of fuel on the O-ring before inserting as the FSM mentioned? My bet is one that O-ring just twisted a bit on insertion.
Old Dec 5, 2010 | 02:24 PM
mlrtime99's Avatar
Ya I'm hoping twisted, yep made sure they were all slick and that the injectors rotated around freely after mounting the rail.
Eggslinger
Jun 8, 2019 03:32 PM
Doug4320
Mar 24, 2018 10:11 PM
raptor510
Feb 17, 2017 07:11 AM
pyramid
Jul 30, 2015 10:05 AM
karbin
Jul 5, 2015 11:37 PM
