How's my gear pattern?
Old Dec 10, 2012 | 05:55 PM
Tadrock's Avatar
Anyone with some knowledge help a first timer out?
Initial set up (no crush sleeve)
Toyota 8"
G2 gears
All new bearings
.093 Pinion Shims
.007 Backlash
15 inch pounds preload\
A big Mahalo in advance
Drive side
Coast side
Old Dec 10, 2012 | 06:14 PM
Krazy Ken's Avatar
That looks pretty good! That would work fine but if you are a perfectionist I would add roughly .005 to .010 to the pinion depth and see if the pattern will go a tad deeper (into the root of the tooth) on the push side.
Old Dec 10, 2012 | 06:19 PM
mudpunisher's Avatar
yeah maybe a little deeper (at least that how it looks in the pics) and .007 backlash seems on the tight side, i try to get around .010
Old Dec 10, 2012 | 06:34 PM
Tadrock's Avatar
Thanks for the response guys. I'll add a little more shim and see what happens.
I was told that .007 was a good backlash to have for new bearings...
(From Zuks website www.gearinstalls.com)
norcal98
Aug 10, 2015 06:20 AM
wolfpackfan33
Aug 2, 2015 03:36 PM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
noahstancik
Jul 17, 2015 05:38 PM
