View Poll Results: Do you use a torque wrench?
Yes, (this means even for minor items like spark plugs, lugnuts, oil drain plug).
117
30.00%
Sometimes, this means for like head bolts, tranmission bolts, etc.
205
52.56%
No, I use touchy, feely method.
68
17.44%
Voters: 390. You may not vote on this poll
How many of you use torque wrenchs?
Old Mar 4, 2004 | 12:56 AM
X-AWDriver's Avatar
My Eclipse had an aluminum valve cover and head and torqueing those to the right specs was crucial since any overtightening would crush the soft metal. The valve cover bolts only used about 10ft lbs of torque which is pretty much just finger snugged and can fool you if you are just guessing with a regular wrench and I've seen alot of damage done with guesstimates.
Old Mar 4, 2004 | 05:33 AM
4RUNR's Avatar
Guest
Since we are on the topic: aren't all torque figures given for 'dry'? i.e. applying lubricants (ex. anti-seize) will lower the torque figure.
Old Mar 4, 2004 | 05:45 AM
platform389's Avatar
Originally Posted by Corey
I have a Craftsman. I can't even remember how long ago I bought it, but I'm sure it was around '91.
Can't remember when you bought it...?
Then it is long past time for recalibration.
... and are you in for a treat.
First finding someone at Sears that even knows what a recal for a TQ wrench is will raise the blood pressure.
My last Craftsman was gone for SIX MONTHS before someone at UPS stole it. I took the claim money and bought a Snap-On to replace it.
Torque all drain plugs, and lugs nuts among other things.
Old Mar 4, 2004 | 05:54 AM
MTL_4runner's Avatar
Phil, I have the entire box lined with Griot's non slip liner.
Keeps the tools from sliding, real nice stuff.
Mohamed, hate to say it but my tool, ah er, my tool box is bigger than yours
It's a 4 drawer one. Same as yours, but with one more.
http://www.pnw4runners.net/temp/toolbox1.jpg
http://www.pnw4runners.net/temp/toolbox2.jpg
Most of the tools inside are Craftsman too.
Just bought a new set of pliers as seen in the top left drawer.
Also bought those ratchet wrenches several months ago, those are great tools.
I try to buy only Craftsman tools.
Corey
Corey, I can't see any of your links?
Old Mar 4, 2004 | 06:06 AM
  #25
SkyRat's Avatar
That is because his message is a year and a half old and the link has expired...
Old Mar 4, 2004 | 06:14 AM
  #26
hahahaha......didn't look!
Who brought this thing back from the dead?
Poll was still open too! :wtf:
Old Mar 4, 2004 | 08:19 AM
  #27
ALBPM's Avatar
My wife uses one on me every time I order new stuff
Old Mar 4, 2004 | 10:19 AM
  #28
Aren't you talking about a BFH.
Old Mar 4, 2004 | 10:38 AM
  #29
ALBPM's Avatar
No, that would kill me.... She still wants me to bring home a paycheck..
Old Mar 4, 2004 | 12:48 PM
  #30
Don't they all. .....oh well.
Old Mar 4, 2004 | 02:02 PM
  #31
sick4runner's Avatar
Yeah, i never used one until my dad gave me one that my dad took from my grandpa's house after he died. its a veeerry old craftsman but looks brand new and works great. it really helps me feel sure about torquing things down i.e. spark plugs, without fearing i might rip the threads out later.
Old Mar 4, 2004 | 02:06 PM
  #32
Mohamed's Avatar
Well I don't know if I mentioned this in the thread or not, but my father bought me a craftsman tw for my birthday last year. Pretty slick I think, though I wish I would have used it when installing various lines in my mom's Camry last week, I know I stripped one of the top bolts on the a/c compressor, as I knew it was aluminum but didn't think while tightening one of the bolts. I can't just bust it loose either unless I want to have a leak of refrigerant.
Old Mar 4, 2004 | 04:05 PM
  #33
kford's Avatar
never taken anything apart that I really needed one for. i've got about the nicest ratchet and socket set there is with all the extenstions and adapters you coudl think of, and I haven't done any major engine or tranny or susp. modding or repairing that would require one. But i have used one before and they are cool.
Old Mar 4, 2004 | 07:13 PM
  #34
Yoter's Avatar
Guest
I use to have a Crew Line TW but when I stopped turning wrenches I sold it. Now I have a Craftsman that is still in the box from Xmas. I need to get in gear and put it to work. I voted for torquing onlyt when need be. I don't go as far as to torque the chrome muffler bearing on. I'm a pro just using the screw driver on that.
Old Mar 4, 2004 | 07:25 PM
  #35
AgRunner06's Avatar
Originally Posted by Samgotit
Hello All,
If you do decide, after seeing this thread, to get a torque wrench don't get the cheap 1/2" $9-$20 Pittsburgh a la Harbor Freight. I've had 2 and neither releases even at 15 lbs. I didn't expect much but I did expect it to release. I really like most of there other tools and the store (they have a Sears like replacement policy) but the torque wrench is now a nice breaker bar. Hell... for $9.99 I really shouldn't complain.
I bought that same one. I used it when I did my front rotors. It seemed to work fine for me. After following the instructions on 4x4wire and using their torque specs, everything seemed to move smoothly and didn't seem overtightened at all. It's supposed to be within 4%.
But yeah, I've got one but I don't use it very much.
Old Mar 4, 2004 | 09:01 PM
  #36
boogyman's Avatar
I just bolt on till it's tight (or appropriate feel)
Old Mar 5, 2004 | 06:20 AM
  #37
MAIS0N's Avatar
Originally Posted by Mohamed
I do have to fix a leak oil pan gasket on my Honda
GET THE TORQUE WRENCH! Those neoprene oil pan gaskets on the Hondas are very sensitive to proper torque and pattern (torque sequence). Here is another tip: Make sure that all the sealing surfaces that the gasket will contact are well wiped down. I usually use a rag with a little mineral spirits to clean 'em up real good. If there is any oil on there the gasket will keep gishing out of the seam before you can get it tightened down right.
EDIT= I'm an idiot. His post was like 2 years ago. Oh well, hope he didn't bork his gisket.
Old Mar 6, 2004 | 07:23 AM
  #38
JSharp's Avatar
Originally Posted by Shane
Really important things... Grunt and a half
Kind'a important things... Grunt or so
Ah, who cares... Snug and a quarter
Hmm. I'll have to try this. I always use "tighten it until it gets loose, then back it off 1/4 turn."
Seriously, I have a Snap-On clicker type ft/lb wrench I use on most things, and a Craftsman in/lb beam type wrench for small stuff...
Old Mar 6, 2004 | 12:53 PM
  #39
bobzemuda's Avatar
I have a Craftsman and a Pittsburgh 3/8" torque wrench. I keep the Pittsburgh in my truck and use the Craftsman when at home.
I started buying an extra set of Craftsman tools to keep in the truck, but after buying an extra 3/8" ratchet and metric socket set, I thought to take the trip to Harbor Freight and see what there stuff was going for. The 3/8" torque wrench was $10. A 14 metric wrench set was $13.
I wouldn't want Pittsburgh for my first tier tools when at home, but to avoid keeping an incredibly expensive set in the car, I think they're better then buying one of those crappy car kits.
I can't bring myself to leave the Craftsman's in my car anymore, because my buddy's Jeep XJ got broken into and all of his tools were in it from a run the day before. They stole them all, and I'd rather be out $50 worth of tools then $250 if the same thing ever happened to me.
Bill
Old Mar 6, 2004 | 03:29 PM
  #40
L33T35T 4Runner's Avatar
you consider lug nuts a "minor" thing? wow... imagine going 65mph and not tightening those down with a torque wrench becuase you thought it was a minor thing...
ya.. i use a torque wrench for everything
