Hood-mounted lights
Old Sep 15, 2007 | 10:55 AM
drguitarum2005's Avatar
From: Houston (home), Atlanta (school), Cincinnati (work)
Hood-mounted lights
so i have these lights mounted to some brackets that i made from 1/8" steel (or maybe it was 3/16...) that go into my hood channel and bolt in in one place, the factory fender bolt, so i didn't have to drill any new holes in the body. they are out far enough to clear the hood and high enough so the light mounting bolt doesnt hit my fender, but due to the length of the metal and the thickness (it can't be any thicker to fit in that channel), the lights shake like CRAZY. when i hit their resonant frequency around 60 mph or so they shake uncontrollably and its very annoying and loud. im looking for new mounting options. does any one have any ideas where i can put them somewhere around their current location, the base of the pillar, or somewhere on the pillar, without any MAJOR modifications? thanks! here are some pics:
Old Sep 15, 2007 | 11:25 AM
KevinInSac's Avatar
The only thing I can think of is:
1) Use another piece of metal, and brace the mounts.
2) Relocate the lights closer to the windshield and use a smaller bend in your bracket. That's probably require you to do some drilling though...
Old Sep 15, 2007 | 01:18 PM
drunberg's Avatar
Get another piece of strap and weld it to triangulate the bend, that should kill the resonance.
Old Sep 15, 2007 | 01:41 PM
dropzone's Avatar
Fossilized
What the previous post have said will work, but you will probably still have some shaking due to the thin material..
One thought would be to make a bracket that mounts to your mirrors and thread the wiring through the Mirror mount and down through the door. Kind of like a big FJC turn signal.
Old Sep 15, 2007 | 02:14 PM
89silverpu's Avatar
I don't have any ideas, but could you post some pics up showing the front of the truck from a little distance, I wanna see what both look like at the same time.
Old Sep 16, 2007 | 03:15 PM
Adam F's Avatar
Why not put them on the front bumper?
ashersullivan88yota
Jan 18, 2022 05:37 PM
4.34runner88
Aug 11, 2018 10:44 AM
AkitaDog
Sep 1, 2015 08:05 AM
PopsDad1
Jul 30, 2015 02:21 PM
Odin
Jul 15, 2015 09:28 PM
