hg leak
Old Dec 11, 2009 | 02:27 AM
toy-o-tah's Avatar
hg leak
how do you know if you have a head gasket leak? my truck has bad idling and feels like its always gonna die when i am at a stop light or when i am at home and i start the truck? i heard it could be the thermostat cause when i drive on the freeway my coolant comes out all over the floor...but anyways my idle is revs up and down or it just dies. k thanks for any help in advance
Old Dec 11, 2009 | 04:05 AM
toyotabull's Avatar
Well if you have coolant on the floor, you have a leaking heater core. If you run a compression test that should tell you, if you have 2 cylinders side by side with lower compression than the other 2, or if your seeing air bubbles in your radiator with the cap off. Is it carb or injection
he's gone
7
Dec 3, 2019 07:08 AM
4runnerjunk
Aug 22, 2015 09:06 AM
accuracy
Aug 4, 2015 08:05 PM
itzmywife's
Jul 25, 2015 04:55 PM
Avenged
Jul 9, 2015 07:55 AM
