Help with Fixing E-Locker
Old Sep 17, 2009 | 08:22 PM
89silverpu's Avatar
FWIW Toyota gears are "the easiest" gears to set up. I have a couple buddies that set them up without even using the proper tools and just eye balled it and they haven't had any problems running 37's+......if you can get the right tools and follow some instructions, go for it. Why not? I knew nothing about E-locker retro fitting nor dual cases, and I put both of them in my truck by myself after researching. Go for it...
Old Sep 17, 2009 | 09:58 PM
cr@ves4wheelin's Avatar
Originally Posted by 89silverpu
Is that a factory TRD axle? Or did the previous owner cut it? If it's the factory TRD axle from a tacoma, you'll have to move the spring perches etc to match up with your mini truck leafs. Almost more hassle trying to modify the TRD axle than to modify a mini truck axle. Not to mention, I think the Taco axles are wider....someone correct me if I'm wrong on that. You can click on the link to my e locker build thread in my signature to check out my build up which may answer some other random questions you may have
Crap I was wonderin about that. Yeah I think he said it was straight out from an '02 tacoma. Dang, well...I can get rid of the axle and keep the e-locker and try to retrofit it I guess. What do you guys think?
Old Sep 18, 2009 | 07:17 PM
Yeah, tomorrow I'm taking the axle housing to the junk yard. I took the long studs and an extra short stud to begin preparing for retrofitting.
Anyways, Thanks you guys. I'm not gonna start this for a while until I find a way to regear to 4:88s. Oh and also thanks for letting me know about the tacoma axle not fitting onto my pickup 89silverpu. That would have sucked trying to try to put it on there and finding out it didn't fit at the last minute.
Old Sep 19, 2009 | 05:59 AM
ScottyC's Avatar
I would tend to disagree. I can't tell you how many 3rds a year I have to re-setup because someone tried to do it themselves, and/or blew them up on the trail.
Toyota gears are extremely sensitive to proper setup if you want them to last. If they are setting them up without the proper tools, then its only a matter of time before they have issues. Either gear pattern or bearings.
Its easy to adjust backlash, but the pattern needs to be perfect if you want them to last and be strong. You're talking about a 7.8" ring gear not a 11.5" ring gear. Pattern, backlash, and bearing preload is a must.
Old Sep 19, 2009 | 08:53 AM
  #25
89silverpu's Avatar
Maybe they got lucky then cause they've been running them for a while, or maybe they went back in and properly set them up after initially throwing them in. The point of my original post was just encouraging the guy to try it himself "with the proper tools." Everyone's gotta start somewhere even the best gear set up gurus had to learn.
Old Sep 19, 2009 | 08:57 AM
  #26
Alright thanks for the input ScottyC, I'll be saving up for some proper tools then.
Old Oct 16, 2009 | 12:47 PM
  #27
4runner Freak's Avatar
Originally Posted by cr@ves4wheelin
Then there's this 2 pin plug. The guy I bought it from said it was busted so I guess I better call Toyota for a new one. I think it just screws out with a wrench.
Have you gotten an answer on the plug?
I just got an e-locker that the same plug is broken.
Where can I find these? Toyota PN?
Anyone? Anyone? Bueler?
Old Oct 16, 2009 | 03:20 PM
  #28
I think Toyota should be able to give you a replacement part. It just screws out.
I haven't called them because I put this project on hold for now.
Old Oct 20, 2009 | 11:26 AM
  #29
Here is the PN for the 2 pin component: 84222-12010
http://www.toyodiy.com/parts/p_U_200...AB_4101.5.html
http://www.toyodiy.com/parts/p_U_200....html?hl=84222
I'm going to see if the indicator from a t-case or ADD will work for it.
Here is the link to a thread I started on Pirate.
Pirate Thread
Old Oct 20, 2009 | 03:46 PM
  #30
sweet man. Thanks a lot.
Jun 1, 2021 01:51 PM
crammit442
7
Nov 29, 2017 12:30 PM
Peevedkitten
11
Aug 31, 2015 06:57 PM
hollypots
North Carolina
13
Aug 31, 2015 04:08 PM
AaronM
Jul 8, 2015 07:15 PM
