gears?????
Old Mar 13, 2008 | 02:59 PM
racingcameron66's Avatar
ok in that case where do i need to get gears from
Old Mar 13, 2008 | 03:03 PM
and what do i need to buy
Old Mar 13, 2008 | 03:36 PM
'884Runner's Avatar
When calculating gas mileage, have you taken into account the final drive ratio that has now changed due to gas mileage? You may actually be getting better gas mileage than you think because of this. Your truck is showing a certain percentage lower miles to the tank than you are calculating.
Old Mar 13, 2008 | 04:13 PM
ILLINOISYOTADAWG's Avatar
you might need to have the comp reset for the tires from the stock size to
the 33's i know when i put 35's on my 95 i had to i pick-up 5miles to the gal
Old Mar 13, 2008 | 05:48 PM
  #25
ya know i havent thought about that, and it makes perfect scence, duuuuuuuhhhhh on me
Old Mar 13, 2008 | 07:45 PM
  #26
AxleIke's Avatar
First of all, if you are not calculating your mileage with the new tires, you are definitely not getting 12 mpg.
And don't do ANYTHING to the computer. That would be a complete waste of money. We are talking 3rd grade math here. Write the number in your gas book, and multiply on the calculator at the pump. Literally one extra step. Takes 2 seconds.
Old Mar 13, 2008 | 07:54 PM
  #27
tc's Avatar
tc
Well, now, wait a minute here ... his speedo COULD be MORE accurate with the larger tires - mine was!
BUT to compare before/after, you definitely need to calculate the tire size difference in.
Old Mar 14, 2008 | 05:03 AM
  #28
Brenjen's Avatar
How's unplugging the battery to reset the ECU a waste of money? Sometimes you guys slay me.
Old Mar 14, 2008 | 07:30 AM
  #29
AxleIke's Avatar
Wasn't referring to your post, but rather what I took from this post
Your post made perfect sense, and is not a waste of money. But to me "having" the computer reset for 33's meant take it somewhere and have the speed sensor stuff redone to be accurate for 33's.
I should have clarified, don't pay to have the electronics redone for bigger tires.
Old Mar 14, 2008 | 08:57 AM
  #30
Brenjen's Avatar
Ah, sorry. My confusion.
Old Mar 14, 2008 | 10:37 AM
  #31
crolison's Avatar
I am running 4.56 on my 2.7 with 32's and during the summer i get around 22-23mpg, right now with alot of wind a huge elevation change and winter gas i am getting around 16-18mpg
Old Mar 16, 2008 | 02:16 PM
  #32
what calculator are you talkin about? and how do i figure out how off my odo is?
Old Mar 16, 2008 | 02:50 PM
  #33
86tuning's Avatar
Take your current tire diameter (measured with a tape) and divide by stock tire size (again, measured with a tape). Then multiply by the mileage you think you're getting.
eg:
32.5" / 28.3" * 12.9 mpg = 14.8 mpg which is in the 'acceptable' range due to leadfootitis at high freeway speeds.
Also, slow down a bit. Using the above tire sizes, at 75mph (indicated) you're actually going 87mph!!!! So to go 75mph actual you should be driving at 65mph (indicated). Fuel economy at 75mph is much better than 87mph due to wind loading (aerodynamics).
Old Mar 16, 2008 | 02:53 PM
  #34
4x4YOTA's Avatar
so i filled up last night and i got 196 miles on a 16 gal tank, so thats like 12.06 mpg what can i do???
wow thats bad I got 312 miles on my 16 gal. tank with my old 33x12.5 but Im running my stock 4.56:1 gears
Old Mar 16, 2008 | 08:20 PM
  #35
AxleIke's Avatar
eg:
There you go. The only calculator you need is a 5 dollar one from the store. Keep it in the glove box with your mileage book.
If you regear, you also throw that ratio in there. I figured mine out, wrote down the first two digits in my book, which are 0.97. Every tank, I multiply my mileage by .97 to get my true mileage.
Easy.
Old Mar 16, 2008 | 09:24 PM
  #36
muddpigg's Avatar
When i bought new tires my mileage dropped a few mpg's. but the new tires a super aggressive and weigh more. tread pattern and width makes for more rolling resistance and more weight, well you get the point.
Looking for some cheap 33x9.5/10.5x15, anybody? for pavement pounders.
Will say I love the off road performance and regearing helped.
Old Mar 16, 2008 | 10:14 PM
  #37
apalmer1's Avatar
What gears do you have right now? Im running 33x1250x15 with factory 4.10's and the 3.4L and i get wayyy better than 12mpg. Hell i fried my ring and pinion a few weeks ago and i just picked up a yukon 4.10 rebuild kit for it, i was considering regearing both ends to 4.88's but frankly the 4.10's do just fine.
Old Mar 17, 2008 | 08:42 AM
  #38
tc's Avatar
tc
NOTE: These calculations are ONLY valuable for COMPARING against what your MPG are before the mods. There is no need to do them every time!
The reason I say this, is because in my experience, our speedos are off SIGNIFICANTLY from the factory. The ONLY way to know is either time over distance or compared to GPS.
Also, the odometer is the backup to the gas gauge - you need to be aware of how many miles you get per tank on the odometer, whether it is actual mileage or not ...
Old Mar 17, 2008 | 08:49 AM
  #39
cool thanks guys, yall have helped me alot
mskalmus
May 28, 2017 07:51 AM
norcal98
Aug 10, 2015 06:20 AM
wolfpackfan33
Aug 2, 2015 03:36 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
