Gear Lube - Diffs/Transmission
Old Apr 22, 2006 | 08:28 PM
CoedNaked's Avatar
HOw often (either time or mileage or both) do you change your gear lube in your manual transmission and differentials? What brand of gear lube do you use?
I'm thinking of switching to Mobil 1 Gear lube 75w90 for my tranny and diffs.
Old Apr 22, 2006 | 08:29 PM
AH64ID's Avatar
AMSOIL, every 3 years, or when contaminated....
Old Apr 22, 2006 | 09:16 PM
humanoid's Avatar
Every 15K for the tranny and the diff. Will be using Amsoil for both soon.
Old Apr 23, 2006 | 07:53 AM
Elton's Avatar
i got 175k on my gear oil..i was thinking of changeing it but it looks like a good bit of work to do it
Old Apr 23, 2006 | 08:08 AM
fireteacher's Avatar
According to my HAYNES manual (1-36), the transmition fluid change as well as the diff fluid intervals are 24 month or 30,000 miles. Why do you change at 15 other than it dosnt hurt to do it early?
this is for tacomas/runners/and t100's
Old Apr 23, 2006 | 10:30 AM
GSGALLANT's Avatar
Old Apr 23, 2006 | 10:59 AM
Elton's Avatar
lol im thinking of useing GL-4 for everything ???
Old Apr 23, 2006 | 11:25 AM
TACOMANATOR's Avatar
Mobil 1 is fine for the diffs and transfer case but might be too slippery for your tranny. Try Redline MT 90 for your tranny, its a GL4 synthetic.
Old Apr 23, 2006 | 11:28 AM
AH64ID's Avatar
I had this problem in my 95 runner with amsoil, after 3K too slipery and woulnt shift. But that was a ADD rig. I now have a non-ADD 92 with a different tranny, I am going to try amsoil again, and if it doesnt work I will go 1/2 and 1/2 probally.
Old Apr 23, 2006 | 12:13 PM
kyle_22r's Avatar
you're nuts!
i just did a change of fluids on my truck, i'll let the rear end go 50K before the next change. probably never will touch the tranny or t-case again.
Old Apr 24, 2006 | 02:42 PM
Toyopnoy's Avatar
So i'm getting the idea that no one has had leak problems with using synthetic gear oils in the diffs and trannies which answered one of my questions. Has anyone had any probs using the Amsoil synthetic ATF fluid in their auto trannies? I have an 86 4runner 4speed.
Old Apr 24, 2006 | 02:59 PM
kyle_22r's Avatar
the leak problem is on old engines with seals that may have been kept from leaking since they were gummed up with crud. generally on most toyota engines this won't be the case, since they have 1 piece rear main seals, positive type valve stem seals, and most of the oil pan gaskets are nothing more than gasket goo.
on a transmission or axle, this just simply isn't a problem.
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
altydog
Jul 28, 2015 10:20 AM
calderp
Jul 27, 2015 09:58 AM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
Hamonacracker
Jul 17, 2015 08:33 AM
