front/rear axle width
Old Nov 28, 2006 | 04:33 PM
HAVOC's Avatar
Question front/rear axle width
What's the difference in rear axle widths between a 1983 pickup, and a 1990?
If I do a IFS hub swap to the '83, will installing a rear axle from 1990 make the front and rear widths the same? (or will I even need to?)
Are wheel spacers (1",2",3") just used so the wheel doesn't contact the bigger (V6) calipers?
Thanks.
Old Nov 28, 2006 | 04:48 PM
Adam F's Avatar
86 and up rear axles are 3" wider than previous years.
Get a widening kit or 1.5" wheel spacers to get the correct width.
Wheel clearance on the rear usually isn't a problem, but the front might be, depending on your backspacing. I have 2.5" backspacing, and I added some .25" wheel spacers, and it still rubbed my V6 calipers. I had to grind the fins off the caliper AND use the spacers for it to clear.
FYI your not going to hurt anything by running a narrow front. Mine is narrow, and doesn't affect anything. (rubs springs a little, but I need to set my steering stops)
Old Nov 28, 2006 | 08:28 PM
tc's Avatar
tc
Yes. The IFS hubs widen the older SFA to essentially the same width as the IFS rear...
Old Nov 29, 2006 | 07:25 AM
Bill's Avatar
IFS hubs give you an over all width of 58 1/4", where as IFS rear ends are 58 or 58 1/2" wide. what's a quarter inch...nadda
stanz
Oct 30, 2015 10:33 AM
Swampwalker
Oct 12, 2015 09:49 AM
I8URSVT
Oct 5, 2015 07:23 PM
mat
Sep 17, 2015 11:18 PM
