Excessive Crancase Pressure
Old Aug 10, 2010 | 07:06 AM
Phssthpok's Avatar
I have a situation of excessive crankcase pressure. Like...massively excessive. popping out the dipstick, and/or blowing off the valve cover vent line (that feeds fresh air INTO the engine) with a sound like a semi-truck venting brake line air, type pressure. The PCV has been replaced, but I noticed that the hose going from the valve to the intake is collapsing under vacuum. My first step will be to get a stiffer hose and see if that solves the problem, but I'm not holding out much hope.
A compression test is forthcoming to see if it's pistons/rings/head gasket related (I hope it's nothing along those lines) but I was wondering if there might be other issues I cold look for?? I did a search, but didn't find anything that seemed to relate (other that pistons/rings/ HG).
It's early, and I'm stressed (broke down 250 miles from home) so my mind is muddled and having a hard time thinking straight. If anyone has any ideas please share.
Thanks
Old Aug 10, 2010 | 07:21 AM
waskillywabbit's Avatar
Extreme blowby. Bad rings, pcv valve, scored cylinder walls.
Sounds like you need a rebuild.
Old Aug 10, 2010 | 08:18 AM
Phssthpok's Avatar
Yeah, that was my first thought too, but it seems strange that it would happen all of a sudden. It was fine two days ago, then yesterday everything went sideways on me. Of course it has to happen when I'm hundreds of mile from home too.
Can you think of any way I can limp it home (~250 miles) without it spraying oil all over the engine bay?
Old Aug 11, 2010 | 01:33 PM
Phssthpok's Avatar
Well...problem solved...after a fashion.
After a brief commiseration with a couple of local gear heads, the consensus was a buggered engine.:doah:
So I bought another truck off Craigslist. $700 for an 84 Xtra cab 2wd. The 77 will get towed home and the engine gone through over winter. The 84 has fewer things wrong with it, so eventually the two will swap engines and the 77 will go up for sale next spring/summer.:waytogo:
Old Aug 11, 2010 | 01:34 PM
Phssthpok's Avatar
Old Aug 26, 2010 | 07:03 PM
Fireball81's Avatar
Kinda bitter sweat ending..... or is it a begining???
ashamsuddin
17
Jul 22, 2024 03:59 AM
zanzabar0
Oct 11, 2015 02:56 AM
Jdgarrison
Oct 1, 2015 02:11 PM
bradahman
Oct 1, 2015 09:24 AM
Shagool22
Sep 28, 2015 07:53 PM
