Ex. Manifold leak, head and mani are FLAT!
Old Jul 13, 2010 | 06:26 AM
Granth's Avatar
I have an 85 toyota 2wd with a 22r and have come across 2 sizeable exhaust leaks. One at the head, and one at the "collector" where the manifold meets the downpipe. The down pipe I have a feeling is because of the latter part of my exhaust work and its horrible quality (thanks 98 tire), but the manifold has me confused.
I have used a straight edge (aluminum ruler)on both surfaces to see if they were flat, and both surfaces check out. Aside from a new gasket, what can I do?
I have spent my resources on what it could be and have come to you guys for help.
Also, are 2wd builds welcome here?
Old Jul 13, 2010 | 06:36 AM
mightymouse's Avatar
2wd builds are great! make sure you get a quality gasket and check the manifold for cracks. I just picked up a 91 2wd and started my build thread last weak. I think it's titled mightymouses's 91 2wd build up thread. truck's name is travis.
Old Jul 13, 2010 | 06:38 AM
Philbert's Avatar
Are you certain all of your bolts are solid? I had a leak on the 22re and it turned out that the PO had snapped a bolt on the manifold and it was in the head, broken off about 1/4" into the head! This was likely my leak. Luckily we got it backed out to make room for the LCE header
I'd start there.
Old Jul 13, 2010 | 06:52 AM
Granth's Avatar
I will look at it a bit deeper this afternoon after work, but all the bolts seem to have been full length and the studs did not come out. Why would a nut back off a little when I tightened it though? Seems that they were a bit looser than I remember them being. Is there a chance of finding the correct bolts locally, rather than ordering the kit from LC?
Oh, and I would buy a header, but I am bagged and body dropped so I can't run anything off the shelf exhaust wise. It sucks haha. Oh well, it comes with being low
Old Jul 13, 2010 | 07:08 AM
toyotas oem just hit the dealer up for the bolts. That's what i did when i rebuilt my motor. If not the dealer check ebay i've seen them on there a few times. Got any pics of that truck.
Old Jul 13, 2010 | 10:38 AM
Granth's Avatar
Old Jul 13, 2010 | 04:51 PM
Granth's Avatar
should all 10 fasnter holes be studs, or should it be a combo of studs and bolts?I ask because a couple of mine are studs with a bolt locked on them, acting a bolt. If they all need to be studs, and seperate nus, I will get the correct amount of studs and pull all the old ones out.
Old Jul 14, 2010 | 10:09 AM
Granth's Avatar
I just ordered the Dorman replacements as it was a little cheaper than the OEM toyota stuff. I ordered 8 studs, should I have ordered 10?? I know there is 10 holes, but I want to say there was two actual BOLTS and not just 10 studs. Am I wrong?
8 or 10?
Old Jul 14, 2010 | 06:03 PM
thinkin it's 8 and two bolts through the pair ports in the center of the ports. nice truck by the way.
Old Jul 16, 2010 | 07:32 AM
Granth's Avatar
Well, back to square one.....or 0, whichever. 8 new studs, 2 airtube block off plates, and 2 damn exhaust leaks. Looks like it's time to start pricing custom headers and exhaust systems. This is NOT what I wanted my money being dumped into. The UZ swap was supposed to be next year but that's being put on hold if i'm dropping 4-500 in exhaust alone.
Colington
Mar 8, 2020 09:51 AM
Sep 4, 2015 09:27 AM
Coreyr384
Jul 10, 2015 11:13 AM
87blyota
Jul 10, 2015 04:31 AM
Avenged
Jul 9, 2015 07:55 AM
