emissions help please
This is related to my 93 p/u in my signature. I have now failed emissions testing 6 times in almost two weeks. Here are my test results from the tests.
HC (Limit 174) // CO (Limit 1.96) // NO (Limit 1121.0) // CO2(no limit)
T1 195.7 // .52 // 654.4 // 14.3
T2 196.2 // .52 // 638.2 // 14.28
T3 203.7 // .48 // 628.7 // 14.31
T4 209.6 // .53 // 593.1 // 14.25
T5 205.5 // .51 // 651.2 // 14.15
t6 219.7 // .54 // 679.2 // 14.21
Test 1 - 3 were all done on the same day Feb 28
Test 4 March 8
Test 5 March 9
Test 6 March 10
Here is what I have done so far
Prior Test 1 - let truck run (parked) for about half an hour. Then drove it for about 20 minutes prior to test
After Test 1 / Prior to Test 2 - ran a seafoam style cleaner through motor, which caused a big cloud of smoke. Then did an oil change. Then drove it for about half an hour, exhaust smelled like gas then went to get tested.
After Test 2 - drove the piss out of the truck, about 200 miles then went to get tested and put dry gas in the tank.
After Test 3 / Prior to Test 4 - Ordered an EGR valve. When it came in installed it and then drove for about 150 miles. Then went to get tested.
After Test 4 - Me and two other people started going over the engine and found a big leak in the intake after the AFM before the intake manifold. I fixed that, re-calibrated computer and noticed a difference in power and how it ran. Ran some more cleaner through the motor and some more smoke came out. Not as much as before. Exhaust still smelled a little like gas
After Test 5 - The same two other people and me went over the motor again and found that the EGR modulator filter was rock solid so we borrowed one from another vehicle. Then we noticed that the truck smelled a lot like gas so we checked the charcoal canister. It was clogged. We blew that out and were eventually able to get air to pass through it. We also checked my plugs. Nothing abnormal other than they were a little white. The air filter was also filthy so I cleaned it (K/N drop in filter). The next day I re-calibrated the computer started the motor and I had white smoke all over the place. I filled it up with 92 octane and I ended up driving it for almost 3 hours between 70 and 75, about 200 miles. I have a lot more power, engine runs smoother, motor idles better, and I have no gas smell in exhaust. Next morning I drive to work (20 minute drive at 35 mph) and when I get there I notice that my exhaust smells like gas again a little bit.
After Test 6 - Failed again with the highest yet in HC. Now I am pissed. Yep my exhaust smells like gas again, what the f#$&??!!!??!!. I order a new charcoal canister and EGR modulator from Toyota.
Here is some more info about my truck:
- my truck has 228,000 miles on it
- 9 months ago replaced my cat and muffler with magnaflow free flow cat and flowmaster 40 muffler and went to 2.25 pipe
- 3 months ago I did a plug, wire, dist cap, and rotor replacement.
- air filter cleaned two days ago.
- fuel pump replaced two years ago.
- same fuel filter as when i bought it 2.5 years ago. I tried to change it, but lines are frozen to filter. Haven't gotten around to dealing with it yet.
- radiator replaced two years ago
- oil change, I run synthetic
- when warm engine idles about rought 500 rpm.
- HG done at 98,000 miles
- I have never changed O2 sensor
- My check engine light is it not on and the bulb does work. I checked.
- I have not bothered to check for codes since above is not on
- I have a snorkel on it and the fan at the e-check does not point at the snorkel
- motor used to run a less than half on the temp gauge. Noticed about 4 -5 months ago now at half
- radiator full and clean
- no oil leaks or drips. I have placed cardboard under it numerous times.
- I do need a quart of oil about once a month and I think that is due to my oil pan seal leaking a little. I dont drop oil but there is the flow by from air on the bottom end which I think is slipping by a little when I am driving
- I can take off my oil fill cap and I engine falters a little, but not much. before I found the intake leak the motor would almost die or die.
- I have removed the ISR and replaced intake tube with stock since boots were leaking.
Here is the kicker I am now driving on expired tags, my birthday was in February, and I need all the help and insight I can get. Does anybody have any ideas, experience, or thoughts that would help me I? could use all the help I can get at this point
Test 4 March 8
Test 5 March 9
Test 6 March 10
Well today I replace the charcoal canister, egr modulator and o2 sensor and only missed by 2 points. then i went and struggled through changing my pcv valve and I passed. I am so tired right now I can't even be excited. Thanks for all of your help
THough I see you passed, HC is left over fuel, 3 Other things you can still check.
1 is you may have a stuck injector, This could even be a leaky coldstart injector or even the Coldstart switch gone bad.
2 The pressure up VSV could be plugged or not working, Pull the hose off the FuelPressureRegulator, Put your tounge on it and rev the engine, If the vacuum doesnt change then the VSV has problems.
3 CAT isnt doing its job.
Fixing ether 1 or 2 if there bad will improve gasmilage.
compression chk...
one injector on my 22re was clogged and made my high rpm hc greater than they should have been on a rebuild.
i only have 1000mi on my rebuild and adding new injectors on top of that made a big difference, at least as far as four bangers go
LONESTAR
LONESTAR
kawazx636
Oct 6, 2021 03:03 PM
Boomer8404
Sep 24, 2015 01:12 PM
Other than that sorry, I have no smog testing experience. Does the cat maybe have anything to it?
