EGR valve ports question
Old Jun 11, 2009 | 11:05 AM
desertcamper67's Avatar
I have the EGR valve out for some cleaning and want to know if the port in the second picture should go all the way through and is it wide open in there or does it come to a smaller opening inside the pipe?
When I took off the vaccuum line to this port I saw all kinds of dry crusty buildup. So after hours of cleaning it with assorted wires and carb cleaner I got the wire in to what seems the inside of the EGR to head pipe. The thing I don't get is my wire still bottoms out inside and I can't seem to get anymore crud out of there.
The screw is not budging and I'm not interested in drilling and tapping so it stays.
Does anyone know what the inside of this port is like?
Attached Thumbnails EGR valve ports question-100_2539.jpg   EGR valve ports question-100_2541.jpg
Old Jun 12, 2009 | 08:16 AM
LD's Avatar
LD
Yea, that is just pressed in, and that flat part's screwed down to hold it. It goes in a 1/2 inch or so, and just opens up to the main passage in there. If you got all the crud out with a wire thats cool. I had to straighten mine out and drill with a 3/32 or so drill bit to clean mine. then you can plug the bottom (where it mounts to the head) w/ your finger and blow into the tube to see if the air leaks by the valve.
Old Jun 12, 2009 | 07:32 PM
Thanks I got through. It took lots of elbow grease but I finally got carb cleaner coming out the bottom. I was about to call it good enough but persistance paid off.
I'm off to the smog shop again tomorrow.
tj884Rdlx
Aug 28, 2015 12:04 PM
montanatruck
Jul 25, 2015 03:45 AM
Poppie51
Jul 23, 2015 05:03 PM
Poppie51
Jul 16, 2015 06:16 PM
87turboPA
Jul 9, 2015 05:58 AM
