EFI Fuel Pump Bracket Question
Old 07-10-2009, 08:06 PM
85TurboRunner's Avatar
I just got a new tank since my old one had a couple cracks it. The new tank is larger capacity so that means my fuel pump bracket is too short to reach the bottom of the tank.
To make it work I am going to weld in a section to the existing bracket to make it longer. (the welding will be done far from the gas tank)
My question is, will it be ok to leave the return line on the bracket the same length or is there any reason that I should lengthen that too?
I don't really see what it would hurt to leave it alone but I just thought I'd see what someone else has to say on the matter.
Here is a pic of the line I'm talking about.
Old 07-11-2009, 03:53 PM
scuba's Avatar
you should be fine with your plan
smthwsn357
05-01-2024 07:28 AM
Charecter1
11-06-2023 10:08 AM
sandyota
02-04-2021 11:16 AM
09-04-2015 09:27 AM
TURBOrunnerNM
07-22-2015 11:01 AM
Quick Reply: EFI Fuel Pump Bracket Question
