downey cold air intake?
Old Jun 7, 2007 | 02:19 PM
2WDoffroadx's Avatar
I'm not sure if my intake is coldair or not, but would a coldair intake make the engine runner cooler so much that it shows up on the temp guage.
Old Jun 7, 2007 | 02:39 PM
Elkaholic's Avatar
No it will not. Colder air is only going to be a few degrees colder. And thats up top at your intake, once it goes into the cylinder and combusts its gone and there is no affect on your engine temp. Ecspecially when the thermostat is down south at the radiator hose.
Old Jun 7, 2007 | 02:40 PM
gilby4runner's Avatar
Its supposed to pull in more air into the intake compared to your stock air intake. It shouldnt make a difference in your engine temp.
Old Jun 7, 2007 | 02:41 PM
Hmm, I wonder why my guage always reads in between MIDDLE and COLD. even with a new thermostat..
When i drive to work in the cold mornings with the heater on, it gets up almost to the middle line, why is this?
And why doesnt it warm up to the middle line normally?
Old Jun 7, 2007 | 03:34 PM
norcalsvx's Avatar
10% more HP for every 10 degres cooler your air temp is
Old Jun 7, 2007 | 03:39 PM
Which means...?
Are you saying I shouldn't worry about it? I'm not concerned if it's running cool, thats just good news for the HG.
I'm just worried that it's innacurate and my engine will overheat. That would blow.
Old Jun 7, 2007 | 03:55 PM
89macrunner's Avatar
Originally Posted by 2WDoffroadx
Which means...?
cold air is denser which means you can add more fuel.
now dont forget you have to take elevation into consideration...20 degree air at sea level and 20 degree air at 5000 feet are going to be diffrent.
cold air intake will sound cool and you MIGHT notice a little bit more pickup.
every toyota ive ever driven..which is many, has always had the same deal with the temp gauge..if its at operating temp its in the middle. anything colder is not warmed up and anything high and you should probably shut er down.
EDIT: if you are concerend about your engine temps maybe you should get a temp gauge!
Old Jun 7, 2007 | 06:34 PM
camdsgn's Avatar
Question 10% more HP for every 10 degres cooler your air temp is
That's really cheap horsepower!
So are you saying if your baseline is 100hp at 80 degrees, you'll have 130hp at 50 degrees and 80hp at 100 degrees?
Old Jun 8, 2007 | 08:28 PM
FredTJ's Avatar
He might be saying that, but if so, then he needs to pay more for his rope.
The crap that he's smok'n now is baaaddddd.....
Im other words BS....
Fred
Old Jun 9, 2007 | 07:30 AM
norcalsvx's Avatar
Fred
i only smoke the finest norcal my man, but yea i just pulled that out of my ass , but cooler air means more power
Blamalam
Mar 12, 2022 07:34 AM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
RatOmeter
Oct 22, 2015 03:17 PM
Tacoma1313
Aug 17, 2015 05:44 PM
calderp
Jul 27, 2015 09:58 AM
