Do bigger tires kill auto trannys?
Old Mar 23, 2006 | 01:54 PM
fdgmotocross's Avatar
My question is simple but i am a newbie and i dont know the answer. I just bought a 97 tacoma with a 6 inch lift and 33s, there is room to put 35 inch tires, so i want to, but my question is, will this wear out the automatic transmission faster? Any imput is appriciated. Thanks, Steve
Old Mar 23, 2006 | 02:09 PM
Ironmike4x4's Avatar
Yes, more work for the tranny especially when it's busy gear hunting trying to get the max power to turn the wheels, that's why it's necessary to regear and it would also be a good idea to invest in a tranny cooler.
Old Mar 23, 2006 | 02:15 PM
Are we talking some kind of additice to the tranny fluid, or actually and aftermarket part that is somehow linked with the tranny to cool fluid?
and if i am only driving occasionally, can i expect my auto tranny to die very quickly? 104k on the truck now, or would it be over a long time?
i cant afford to regear right now. Any more input? should i scrap the 35s?
Old Mar 23, 2006 | 02:41 PM
bob200587's Avatar
Does it have stock gears in it now? You'll need to know before you make a decision. I would go with 5.29s for gears. If it already has 4.88s then you might be ok. if not, def. regear first.
Old Mar 23, 2006 | 03:35 PM
its got the stock gears in now, i think they are 4.10s, so if i do this, is it that much worse going from 33s to 35s? What is the timeframe of how long my tranny will last. And what is the price difference between re gearing front and rear, vs. a tranny rebuild with labor. Thanks, Any more info?
Old Mar 23, 2006 | 03:51 PM
shawn0890ss's Avatar
http://www.allprooffroad.com/index.p...ask=view&id=20
hope this helps
Old Mar 23, 2006 | 04:44 PM
tc's Avatar
tc
Tranny cooler is like a mini radiator to cool your transmission fluid.
35's and automatic NEEDS 5.71 (actually lower, but there aren't any for Toy axles).
Stick with the 33's til you can afford to regear (which is a good time to do lockers too!)
Old Mar 24, 2006 | 07:50 AM
Bobakazi's Avatar
4.10s and 35"s on an auto? That is a lot of extra stress, and you would have almost no acceleration.
Old Mar 25, 2006 | 07:30 PM
InternetRoadkill's Avatar
typical gearing for the auto is 4.30. You can look at the little plaque inside the engine compartment and decode the rear end code to find out for sure.
Old Mar 26, 2006 | 06:13 PM
CoedNaked's Avatar
Sorry, I hate to be cheaky, but won't it wear it out "slower" since everything won't be turning as much?
LOL
Old Mar 26, 2006 | 07:20 PM
MattR's Avatar
Pretty much already been said, but do bigger tires kill trannies? no..heat does. I also echo the aux cooler idea.
Matt
Charecter1
Nov 6, 2023 10:08 AM
Jun 1, 2021 01:51 PM
Sep 4, 2015 09:27 AM
Michael oaks
Jul 27, 2015 11:47 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
