difference in transmissions?
Old May 11, 2008 | 04:05 PM
HAVOC's Avatar
I have a 1989 22RE 4X4 pickup (W56).
I also have a 1995 3.0V6 4X4 pickup (R150F).
What's the difference between the two transmissions? Is it just transfer case shifting (top - forward) or is it something else? Is the R150F an improvement over the W56? If the difference is just bellhousings, can't you swap them?
Old May 11, 2008 | 06:33 PM
tc's Avatar
tc
The R150 is one of the strongest transmissions Toyota ever made.
The only way to mate one behind a 4cyl is with a bellhousing from a turbo truck ... and they are rare.
Old May 11, 2008 | 06:36 PM
DeathCougar's Avatar
I would stick with the W56. The gear case is much stronger IMHO and gearing can be changed if you ever want to upgrade for wheeling.
However, TC is correct you will need an R151F bellhousing (turbo truck) to mount the V6 trans/case combo, as well as having your driveshafts redone.
Old May 11, 2008 | 06:38 PM
tc's Avatar
tc
I think you mean gear drive case.
I disagree about being stronger, but can't argue about the lower gears... chain drive cases are holding up just great behind 4.7 crawl boxes in supercharged Tacos making way more power/torque than a 22RE will ever dream of ...
Old May 11, 2008 | 06:41 PM
shoot i meant gear drive
its my birthday and I have been drinking, leave me be! lol
Old May 11, 2008 | 09:47 PM
cosmo's Avatar
W56: Rev:-4.091
1st: 3.954
2nd: 2.141
3rd: 1.384
4th: 1
5th: 0.850
R150F: Rev: -4.220
1st: 3.830
2nd: 2.062
3rd: 1.436
4th: 1
5th: 0.838
The R150F is stronger. When Toyota introduced the Turbo Truck and 4Runner
in 1984, they developed the R150F, a 4WD version of the R150. It is typically connected to stronger differentials as well. It was a natural carryover to the V6 models in 1988.
Old May 12, 2008 | 07:23 AM
Red_Chili's Avatar
The R151 is stronger and has a significantly lower first gear - but due to that (per Marlin) it will not shift as nicely as the W56. The newer R150s shift better than both and share the strength of the R151. The chain transfer case is not in fact weaker, but the geared case can be regeared which is huge. A geared tcase can be bolted on to any R150, however, with a Marlin adapter.
If I had it to do over, I might have gone with the R150 behind my donor 1996 instead of the R151, and just used the adapter for a Marlin Ultimate. But it works fine and I like the low first when towing and in sticky situations wheeling.
chuckross1957
Jun 28, 2019 10:19 PM
HollieJayyy
Aug 9, 2015 07:59 AM
Tigbucket
Jul 30, 2015 07:29 PM
jjrbus
Jul 17, 2015 07:06 AM
Poncho0206
Jul 10, 2015 06:21 PM
