coolant temp sensor
Old Sep 8, 2009 | 02:09 PM
jdanglesyota's Avatar
Angry coolant temp sensor
Ok so here in my problem, i have an 86 4runner 22re. i cant get it to run at all it fires once and that's it. then if you let it sit for a few hours and try again it will fire once again. truck has been siting for a few years. could the coolant temp sensor be making it think its over heating and be making the ecm tell in to run lean? i know that happens with some of the older Chevys i wasn't sure if Toyota had the same set up. any help would be great.
thanks
Old Sep 8, 2009 | 02:17 PM
rdrttoy's Avatar
starting fluid.
Old Sep 8, 2009 | 02:24 PM
i did that and i can make it run. so i know its a fuel problem. but at soon as i stop spraying it stops runing
Old Sep 8, 2009 | 03:01 PM
cloudedjudgment's Avatar
I had the same problem with my 89. Would start, run great for a few mins then it would run like . CEL said Coolant Temp Sensor, replaced that and she runs great. GL
Old Sep 8, 2009 | 09:05 PM
myyota's Avatar
Have you checked the fuel pump and the thermal time switch ?.
Old Sep 9, 2009 | 09:08 PM
ToyBotz's Avatar
You said it sat for a few years, Bad gas?
Old Sep 12, 2009 | 05:57 PM
fresh gas and i have the fuel pump runing off a jump pack. and i hear it running. i will try and replace the sensor, nice when u got 7 yotas at the house :p anyother ideas would be great. thanks for all the help guys
Old Sep 12, 2009 | 05:58 PM
whats this thermal time switch and where is it?
Old Sep 12, 2009 | 06:00 PM
Lysmachia's Avatar
Temp sensors are cheap (12 bucks maybe?) and when old they often stick. But the one extra nice thing you got going for you? You have a 22re! If you had a 3.0 you'd spend 3 hours replacing the temp sensor!
So I say give that a whirl first!
Old Sep 12, 2009 | 08:11 PM
myyota's Avatar
Try checking the solenoid resister, if its bad your 4Runner won`t start. The one on my 86 4Runner went bad and it wouldn`t start, also check the TPS, ive personally seen those go bad and cause a truck not start. Look below the throttle body and you will see two sensors, the thermal time switch is the larger sensor, it tells the cold start injector when to come on or shut off.
Old Sep 13, 2009 | 09:24 AM
sweet. thank you guys so much. no time this weekend but hopefully i can get to it next weekend. thanks for all the help
Old Oct 5, 2009 | 02:46 PM
runs awesome now!!!!!!!!!!!!!! don't ask me y tho hahahahaha. but it runs like a yota
bighaydn
Aug 4, 2015 07:17 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
Poncho0206
Jul 10, 2015 06:21 PM
bryan34w
Jul 6, 2015 05:53 PM
