Clutch problems need help!!
I had problems with my clutch getting stuck to the floor. I could drive it for a few days by pulling it back up when it stayed to the floor. I could still use the clutch that way.
I tried to gravity bleed it with no luck, so today I replaced the slave cylinder. Again I gravity bleed the clutch. The problem persists. Now I have about half the clutch when I push it down and hold it to the floor. As I release the clutch it pulls itself right back down to the floor and stays there. Somebody know whats wrong? Could I be bleeding it wrong? Master cylinder?
Need some help ASAP!!! Thanks!!!
Paul
Paul
I don't think its anything like that because it seems to draw the clutch to the floor rather then just sink...
I worried that im not bleeding correctly. All I did was open the cap, open the bleeder valve and and keep fluid in the reservoir untill it flowed for a while. Then I closed the bleeder. Is it that simple?
the1998sr5
15
Jul 14, 2020 08:35 PM
the1998sr5
Jul 16, 2015 06:20 AM
