Clinometer plexiglass
Old Apr 5, 2010 | 09:29 AM
seanmearse's Avatar
So, I kinda screwed up. I used a SMALL amount of acetone to remove paint off of my clinometer plexi. The PO painted the truck and didnt feel the need to cover the dash or any interior parts. It doesnt really bother me, but the clinometer face did, you couldn't read it at all. But, now its worse. Im not sure if there is anything I can do to repair it. If anyone has an idea, or something they tried that kicked butt, let me know, I want to get this little guy back in the truck quick! Like some sort of plexi repair kit, or chemical that works wonders.
Old Apr 5, 2010 | 11:24 AM
seanmearse's Avatar
no ideas?
Old Apr 5, 2010 | 11:48 AM
dropzone's Avatar
Fossilized
pretty much you just screwed it up with acetone. it is all cloudy now? Right? how do I know...i went the wrong route once too
I still have an inclinometer on the shelf w/o a face...been looking off and on for 2 years to just find a face but no luck...
Old Apr 5, 2010 | 11:53 AM
seanmearse's Avatar
yup, same boat. I'm gonna call the dealership in a few and see what they can do. I'll post up as soon as i find something out.
Old Apr 5, 2010 | 12:02 PM
dropzone's Avatar
Fossilized
if they have them that would be cool
Old Apr 5, 2010 | 12:04 PM
xxxtreme22r's Avatar
well that sucks, Ive done that to speedo gauges before. All I have been looking for the the clinometer housing and bracket, I don't need a working one, I just want one for aftermarket gauges.
Old Apr 5, 2010 | 12:11 PM
seanmearse's Avatar
Okay, havent called the dealer yet, but did some p/n searching on toyodiy. It comes up with every part available, exept the face!!! AHHHHHH. I'm calling the dealership now.
Old Apr 5, 2010 | 12:16 PM
hilux1026's Avatar
ok is it warped or just hazed out bad???
Old Apr 5, 2010 | 12:17 PM
seanmearse's Avatar
hazed REALLY bad.
Old Apr 5, 2010 | 12:25 PM
hilux1026's Avatar
trying to remember from my old truck. Is the lettering on the outside or in?? if its inside then remove it and get 2000 and 1500 grit wet and dry and wet it and rub. Will take a while doing it this way but you can polish plexi just take your time. make sure you get a rubbinh block as well start with the 1500 then move to the 2000. finish it off with headlight cleaner and you should have a clear glass again. take your time. otherwise i just found one on ebay with brown consol for 175.00
Old Apr 5, 2010 | 12:29 PM
hilux1026's Avatar
or this one on here for 110.00
Old Apr 5, 2010 | 12:30 PM
hilux1026's Avatar
https://www.yotatech.com/forums/f37/...-gauge-202598/
sorry heres the link
Old Apr 5, 2010 | 01:25 PM
seanmearse's Avatar
already tried with a headlight kit, came with some ungodly smooth sandpaper, didnt even phase it. Dealership doesnt have anything. I dont think im gonna keep it for the price. Thinking possibly about putting some aftermarket gauges in it, but Its already sr5, I have all the gauges i need. What else could I use it for?
Old Apr 5, 2010 | 02:42 PM
AzStorm's Avatar
Paperweight?
Meguires has plastic polish and cleaner that may work.
I can usually find it at a local Napa,Pep Boys,Autozone,Checker,etc..
For a few bucks it might be worth a try.
You may also try and give it a light coat of clear gloss spray paint.
Old Apr 5, 2010 | 02:45 PM
broncrider's Avatar
have you tried some buffing combound for plexy glass. i know we used it all the time and it would clear it up real quick
Old Apr 5, 2010 | 02:53 PM
wake_roks's Avatar
i know on my brothers phone screen, he used some 3000 grit sand paper wet..... and it took all the scratches out of it.... the sand paper had a little drill attachment with it so he could spin it pretty fast.... but idk if it would help with the hazyness..... just my $.02
Old Apr 5, 2010 | 03:03 PM
DeathCougar's Avatar
Go to TAP plastics and get a sheet of plexiglass, and use the old face at a template to cut a new piece. VIOLA!
And don't use Acetone on plastic. Dummy.
Old Apr 5, 2010 | 03:06 PM
seanmearse's Avatar
Tried the high speed with high grit, nothing. Im just going to look for an aftermarket that will fit in the housing, kinda a custom look, im not worried as much about looks as functionality. we will see, ill figure something out, thanks for the suggestions guys!!!
Old Apr 5, 2010 | 03:48 PM
stepside trd's Avatar
there is a product called "flitz", might want to give it a try.......
Old Apr 5, 2010 | 04:17 PM
hilux1026's Avatar
ok headlight kits are designed to remove oxidization and very light scratching. Rubbing with wet and dry will not be a 5 minute fix so if you have ADD or ADHD then this isnt for you. This will take time but will bring it back to lcear or very near to it. ADD and ADHD are not a crack at anyone but if you want a 5 minute fix it wont work for you
