Cleaning PCV valve?
Hello everyone. I had a look in the online service manual where it talks about PCV valve and I can't see anything sophisticated about it - just a spring with a valve. So...now the question is if it is reasonably clean and you give it a really good clean in addition to that, make sure it functions as per manual and doesn't stick etc. - is that good enough to put it back in or are there any hidden issues with old valves? And don't start "I would just buy one", please
because if I thought so I wouldn't ask here! I am trying to understand what is it so important about this valve because dealer charges quite a lot for it (at least I think it shouldn't be that expensive - for a piece of plastic ,that is)
ok. my recommendation: buy a new one. they're less than $5 at the local autozone or kragens.
now, if you absolutely cannot buy a new one. i've dipped mine in gasoline before to give it a quick cleaning... make sure it rattles when you shake it (no sticking on the inside).
that should about do it.
and yeah put a new one in yourself.
montanatruck
Feb 26, 2017 07:07 AM
Sep 4, 2015 09:27 AM
