Cleaning an alternator
Old Aug 13, 2012 | 07:22 PM
toyota4x4907's Avatar
This is what the alternator from my 22re looks like.
it is covered in a mixture of oil, coolant and mostly mud. What would be the best way to go about cleaning it without damaging it. Can I dunk it in cleaning solution? Or do I need to dry clean it the best that I can? Wire wheel and such.
Old Aug 13, 2012 | 07:49 PM
rworegon's Avatar
Cleaning solution, brake cleaner, carb cleaner may degrease the bearing(s). I'd scrape that gunk off with a putty knife with the shop vac sucking it up as I scrape. Then split it in two and hit it the inside with electrical parts cleaner trying to avoid the bearings.
Old Aug 13, 2012 | 07:57 PM
Vang530's Avatar
I use this when it starts to get bad:
Never had any problems with it. Available at almost any auto parts store.
Old Aug 13, 2012 | 08:04 PM
Thanks guys
80Truck
Oct 12, 2025 07:25 PM
foampile
Dec 18, 2022 01:29 PM
redneck17
Oct 29, 2015 09:09 PM
Sep 4, 2015 09:27 AM
RBK
Aug 2, 2015 11:33 AM
