Castor Angle 1982 Solid Axle
Old Aug 21, 2019 | 06:52 AM
Trueblue93's Avatar
The question: With machined knuckle caps, can the castor be calculated based on the angle the cap sits? It seems completely logical to me, but I’ve never read this in any of the tech. That angle is 10 degrees on my truck. If true, I need to get at least a 6 degree pinion wedge.
I have converted the steering to hi steer with RUF.
I know there are lots of write ups on castor and the solid axle.
Bryan
Old Aug 21, 2019 | 10:26 AM
arlindsay1992's Avatar
Yes, that is a reliable place the check the caster angle if the top and bottom surface of the high steer arm are parallel.
Old Aug 21, 2019 | 11:55 AM
Trueblue93's Avatar
Awesome! Thanks for the confirmation!
kawazx636
Aug 20, 2013 09:57 PM
6x6 crazy
Feb 10, 2012 09:53 PM
swapped89
Oct 22, 2011 07:08 PM
yoterr
May 26, 2011 05:45 PM
dantlm15
Feb 28, 2010 12:48 PM
