can you identify this
Old Apr 12, 2010 | 03:30 PM
skooterbumm's Avatar
Ok...It was the pump! The pin that goes through the actuating arm is borken. Was still workin though. Ill post a pic later
Old Apr 12, 2010 | 04:36 PM
Ok gnarles, I was smelling coolant in the exhaust, when the truck was running (reason for pulling head) I found #4 cyl starting to go (top of piston all purty and clean)
I may have dumped the parts there myself. I took the pump off before removing v/c. I rotated to clear water neck from tstat. no pics yet maybe tomorrow
Old Apr 12, 2010 | 05:02 PM
http://i435.photobucket.com/albums/q...36Medium-1.jpg
This shows the pin and arm from my fuel pump
Old Apr 12, 2010 | 05:08 PM
and heres the pump body
Old Apr 12, 2010 | 05:09 PM
  #25
http://i435.photobucket.com/albums/q...0937Medium.jpg
pump body second try
Old May 1, 2010 | 10:26 AM
  #26
up date.. i installed a electric pump and pressure reg, I have pressure set to 2psi, (havent actually put gauge on, just the number on reg) and MAN this thing runs great. i didnt believe that the webber only needs 3 psi! It idles better than ever, before it smelled rich at idle.
Old May 1, 2010 | 04:03 PM
  #27
xxxtreme22r's Avatar
which fuel pump and regulator did you go with?
Old May 2, 2010 | 01:20 AM
  #28
seanmearse's Avatar
Originally Posted by Gnarly4X
Yeah... I guess it was making noise! Did the chain break or was it off the sprockets? Any idea how many miles was on it?
For some reason my computer isnt showing me recent threads in user cp. But, nah, chain was still on, but just figured while im in there i might as well replace the chain and all.
Old May 3, 2010 | 09:16 AM
  #29
Its a pump they sell at oreillys, and a mr gasket reg.
Old May 3, 2010 | 10:56 AM
  #30
that dial regulator is not the best thing on these webers. If you search you will find alot of people that have had problems with those. Not sure on the pump though. The best and probably only regulator I will ever use are the Holley regulators. I set mine at 3.5psi. 1.5 psi while offroad.
Old May 3, 2010 | 04:59 PM
  #31
im sure its not the best, it was 29 dollars, only one they had. I plan on ordering a better one, when this one fails
Corvoid
Oct 13, 2015 08:55 AM
JUICE222
Oct 13, 2015 08:50 AM
Bill854x4
Sep 20, 2015 04:32 PM
jdt79
Sep 16, 2015 02:14 PM
DadsTruck
Aug 1, 2015 09:14 PM
