California Smog Limits
Old Nov 17, 2010 | 06:32 PM
Bako88's Avatar
I had my 88 smogged today and failed NOx limit. I then checked my printout from January '09 and found that my truck is slightly better this time, but the max allowed has dropped from 1058ppm to 740ppm. Anyone in Yotatech land noticed this (in CA of course)? Why did they lower it and by so much? Thanks, Walt
Old Nov 18, 2010 | 09:01 PM
Bako88's Avatar
Well, if anyone's interested, I called the smog tech today to ask about the lower max on NOx. He says it was lowered and they will keep lowering it.
I looked through the stuff I rec'd from the previous (original) owner and his smog check in '02 showed 91ppm for NOx. '04 smog check showed over 1000 ppm. I plan to try a new O2 sensor and look for vacuum leaks.
Old Nov 19, 2010 | 05:32 AM
93yotaSR5's Avatar
High nox usually ties into= catalytic converter, egr, and cooling system.
Yesterday a guy passed with using e85 in his tank. There's a thread
Old Nov 19, 2010 | 08:25 AM
93yotaSR5's Avatar
here you go
https://www.yotatech.com/forums/f116...c-3vze-223919/
Old Nov 19, 2010 | 08:44 AM
dirtydeeds's Avatar
just put 20% methanol and run a pre test. You'll find the nox goes down quite a bit, if not enough at least it was a pre test. Go home, put more methanol in there and run another pre test. Repeat until it passes.
Old Nov 19, 2010 | 08:57 AM
Outsane's Avatar
The issue I heard was that in States like California and Arizona old cars don't die of rust like they do on the other end of the country. Old cars have had less strict measurments to pass. So they started making it more strict to help the "planet", in the hope these "gross Polluters" would either get cleaned up or pulled off the road..
So who makes more bad air, Cars or Industry?
Old Nov 20, 2010 | 05:26 PM
Bako88's Avatar
My Cat is relatively new though. I'm thinking about getting a Denso O2 sensor. Need to rule out vacuum leaks too.
Old Nov 21, 2010 | 06:24 AM
93yotaSR5's Avatar
Just got denso o2 sensor shipped for like 55-60$ from rockauto.com
Old Nov 21, 2010 | 06:26 AM
93yotaSR5's Avatar
Make sure your egr is working, and get a spray bottle with soapy water and spray it over the vac lines and see if there is a leak.
Jdgarrison
Oct 1, 2015 05:22 PM
Jdgarrison
Oct 1, 2015 02:11 PM
bryan34w
12
Sep 30, 2015 02:50 PM
dbollier123
Sep 29, 2015 05:23 PM
taraf
Sep 25, 2015 02:57 PM
