A/C Condenser Drain TUbe?
Old 07-19-2008, 04:50 PM
hayn4x4's Avatar
I have found that when i lift up my rubber floor mat on my driver side of my 1998 4runner there is water under the floor mat. I'm not to sure what is casing this but i think it might be my A/C condenser drain tube is clogged up. Can anyone tell me if this could possibly be the problem? Cause if there is no way that this could be the problem then there is no sense in me checking the tube. If it is possible that this could be the problem, can someone tell me how to find the drain tube and how to check if it is clogged and how to un-clogg it. When i run my A/C there is water that drips under my truck. Any help would be greatly appreciated. Thanks.
Old 07-19-2008, 06:55 PM
bigtrucknwheels's Avatar
Location: Where it always works if you work it, in Sunny Selinsgrove, PA
it is more than likely your condensation drain tube. I had the same problem, though I don't know where yours is on your truck.
Old 07-20-2008, 12:31 AM
hayn4x4's Avatar
Thanks man. Can anyone tell me where i can find the condensation drain tube?
Old 07-20-2008, 05:44 AM
mine was on the passenger side of my firewall. and it was clogged, so every time I went around a corner, water would pour out on my floor haha.
Old 07-21-2008, 04:26 AM
91diesel's Avatar
look on the passenger side in the engine bay near the frame and you should see the drain tube, you can then just pull it out and clean it, pop it back in and look inside to make sure it went back over the evaporator drain. Mine is a 91 so your year may vary.
coryc85
12-05-2015 08:42 AM
Ktm526
10-07-2015 05:14 AM
Boomer8404
09-17-2015 07:59 AM
Tacoma1313
09-08-2015 01:27 PM
dguzzi
09-03-2015 08:48 AM
Quick Reply: A/C Condenser Drain TUbe?
