A/C is acting strange.
Old Mar 25, 2008 | 08:02 PM
4WDYotaShop's Avatar
I recharged my a/c and now it cycles on and revs up to like 2000 rpms and cycles off back to normal rpms. I can't figure out why it revs so high. I checked the amplifier and turned the trottle up and down but it makes no difference. Then when I'm driving it kicks on and off quickly and randomly and doesn't work very well.
Thanks
Old Mar 25, 2008 | 08:06 PM
mr_schuster's Avatar
If its an older model truck you can adjust the A/C idle up, by turning it down.
Old Mar 26, 2008 | 09:02 AM
I tried that. The idle control on the amplifier has no effect on the idle. It used to work until recently.
Old Mar 26, 2008 | 01:46 PM
I just realized that there is a screw on the throttle of the carb that is connected to a valve. I think it is the adjusting screw you spoke of. I tried to turn it and it wouldn't budge so I'm gonna spray it and use a longer screwdriver next time.
Old Mar 26, 2008 | 01:51 PM
4Crawler's Avatar
The screw on the A/C Amplifier is used to set the RPM below which the A/C is shut off (to avoid bogging down the engine). It has nothing to do with what RPM the engine idles at, that is controlled by the A/C idle-up adjustment screw. Probably the one you see on the carb.
Old Mar 26, 2008 | 02:15 PM
Sweet thanks. I'll give it a try and see what happens.
Old Mar 26, 2008 | 06:30 PM
Success! My a/c runs great.
Badlander
Oct 10, 2015 08:05 PM
Ktm526
Oct 7, 2015 05:14 AM
bryan34w
12
Sep 30, 2015 02:50 PM
Shagool22
Sep 28, 2015 07:53 PM
JamesDINAN
Sep 22, 2015 05:37 AM
