BudBuilt Skid Plate GROUP BUY!
Old Apr 13, 2006 | 06:19 PM
  #201
bamachem's Avatar
potsy and mat need to step up. out of 33 people, they're the only slackers.
Old Apr 13, 2006 | 11:37 PM
  #202
Stump1883's Avatar
Maybe mine will come today as a Birthday present to myself . Sure is a long time to ship for somewhere that's less than 2hrs away. It's prolly do to the production time, not the shipping.
Sorry I'm a bit from some early celebration. Good times.
Old Apr 14, 2006 | 06:04 AM
  #203
Roadrunner's Avatar
First impressions of my skid and belly pan is that they're pretty stout. I didn't get a chance to undo the packaging, I had to get to training after work. Time to pick up some cans of primer and black paint and work on them this weekend.
Old Apr 14, 2006 | 09:20 AM
  #204
86Original's Avatar
Anyone else thinking about just leaving these unpainted. I think the bare metal look is interesting. Another thought was using POR-15 clear.
Old Apr 14, 2006 | 09:42 AM
  #205
Snorkeldepth's Avatar
I like that idea! Although if you keep touching it up after every encounter with a rock it could get expensive.
Old Apr 14, 2006 | 11:54 AM
  #206
mat's Avatar
mat
you can add my name to the paid list if your still keeping track
Old Apr 14, 2006 | 01:11 PM
  #207
86Original's Avatar
POR-15 clear
The nice thing about POR-15 is that it likes rust, so you could just wait until you have several places starting to rust and touch them up. You should : never be exposing it to UV, so it's OK to leave it w/o a topcoat. I'm just not sure that is worth it out here in CO. With Bud's pickling process it may not be necessary to even paint it with POR-15. Maybe I'll just wait to see if it starts to rust much and then put on the POR.
Old Apr 14, 2006 | 02:31 PM
  #208
Digger33's Avatar
I just recieved mine this morning. Very fast delivery. I was thinking about painting mine, is it necessary? I was just going to do some primer and flat black. Also, it looks like the second set of holes on the stock skid (that has the bracket on it), from the front, are not used for the new skid is that correct???
Old Apr 14, 2006 | 03:41 PM
  #209
86Original's Avatar
Cool! I'll have to run home and see if I got mine, since you ordered after I did and your in CO as well.
Old Apr 14, 2006 | 03:42 PM
  #210
tc's Avatar
tc
Crossmember came today, and got the skid put on. Wow is it heavy duty. A couple notes:
- The packaging on the skid was pretty bad. Lots of adhesive residue had to be cleaned off. Couldn't they put the sticker on the cardboard side? The crossmember packaging was MUCH better.
- I'm disappointed by the lack of installation instructions. At least put something a little more detailed up on the website...
- It was a PITA to get the holes to line up. Ended up having to wallow out the holes a bit.
- I was missing washers for the front (big) bolts.
Will work on the crossmember when the skid part gets here. I hope it goes better.
Old Apr 14, 2006 | 04:27 PM
  #211
garrett1478's Avatar
that's just part of the 20% discount
Old Apr 14, 2006 | 04:32 PM
  #212
86Original's Avatar
Did any of you guys get any tracking information from Bud? Or did the stuff just show up on your doorstep?
Old Apr 14, 2006 | 05:40 PM
  #213
rocket's Avatar
I agree. It took me forever to get that residue off. Hope my 3rd gen skid isn't the same. I'll know tomorrow.
dude, the installation is pretty straight forward.
theres also this...
"If you have problems or questions, please feel free to call at 828-433-1489 from 8am to 10pm, eastern time zone or email to bud@ budbuilt.com"
maybe your rig is a little tweaked outta shape? lol
They don't come with it (front skide plate) but i think they should. I couldn't even find big or thick enough washers. Perhaps custom washers could be supplied? Whatdoya say Bud? I'd actually prefer smaller holes on the upper mounts (2nd gen skid plate) so that a regular washer would fit and look normal.
It really helps having a second pair of hands. I ended up bolting mine to the tranny first (4) and then bolted it to the frame (8). That made lining everything up much easier. You'll also need to buy some grade 8 washers for the 17mm bolts...i used 2 washers per each bolt.
Oh yeah, you'll also have to remove this part before attaching the crossmember...
Old Apr 14, 2006 | 06:43 PM
  #214
tc's Avatar
tc
I got tracking info - but Hotmail tried to block it first. I hear Yahoo does the same thing. Check your Junk/Bulk email boxes. If you can't get it via email, give Bud a call.
Bud is sending washers.
It is very possible that something is tweaked with my truck...
Old Apr 14, 2006 | 07:04 PM
  #215
rocket's Avatar
Do you know any deatils about them? Do they cover up the huge square-ish holes?
Old Apr 15, 2006 | 05:17 AM
  #216
tc's Avatar
tc
Yes - supposely they are extra large and extra thick. (Which is why I asked him to send them instead of going to the hardware store).
BTW - I like the idea of the big holes, it was awful nice to be able to put in one bolt and hang the skid off it while you do the other one...Then I used a jack to press the bottom up flush to get the allen bolts in.
Old Apr 15, 2006 | 08:40 AM
  #217
Roadrunner's Avatar
Upon closer inspection, daylight helped, I only received the front skid plate. I'll call Bud next week to inquire about the belly pan.
Old Apr 15, 2006 | 09:39 AM
  #218
Digger33's Avatar
Ok so i have a question still about the two holes at the bottom where it is bent and goes flat. Do you use those two hole to mount it? They are the holes that are right below the budbuilt.com sticker in the first post. They don't look like they would work for mounting. Also, what hardware was suppose to come with the front skid. I recieved 4 allen bolts and a allen wrench. Then there was the steering rack mount on the skid as well. Is that what everyone else recieved?
Old Apr 16, 2006 | 07:28 PM
  #219
86Original's Avatar
skid in lieu of IFS truss??
1st & 2nd Gen owners, Bud,
I wonder if the skid plate could be used in lieu of an IFS Truss. That's pretty heavy steel. If holes were drilled through the skid and into the ends of the two rear lower A-arm attachments, then the holes in A-arm attachement could be tapped and the skid plate countersunk. Flathead bolts could then be put in to bolt the skid plate the rear A-arm attachment point just like where the SS IFS truss bolts.
Or is the skid plate too narrow?
WDYT??
Old Apr 16, 2006 | 07:37 PM
  #220
rocket's Avatar
Good idea but It's too narrow.
