Best filter for max engine life
Old 03-01-2006, 04:26 AM
SnoViking's Avatar
so i guess im not using frams anymore
Old 03-12-2006, 04:01 PM
84sr5yoty's Avatar
I looked up the cost of a mobile ep oil filters on AutoZone for the 22re motor and found that they run about $11.00 each in my area. Got on good ol’ ebay and found a guy who sells mobile ep filters in 6 packs for 35.99, which amounts to a little over $5.00 for each filter. Pretty good deal in my opinion. I'm going to buy a 6 pack and see how these filters perform. Maybe it'll get rid of my timing chain noise on start-ups. M1-204 is the filter for 22r/re motors.
http://cgi.ebay.com/ebaymotors/6-Pak...spagenameZWDVW
Old 03-12-2006, 05:25 PM
mach4's Avatar
Originally Posted by CoedNaked
That's part of the equation from some of the reading I've done as far as I understand. But the other issue is the oil maintaining it's lubrication properties, and it's viscoscity. For instance some guys who run synthetic oil, just change oil filters at what would be considered a normal oil change interval (for "dino" oil), and then top up lost oil from the filter change and run the oil twice as long as normally would be done. The top up helps (say around half a liter to a liter) freshen the oil up. This also helps keep particulate out of equation, by removing the dirty filter, and since synthetic oil seems to hold it's properities and viscoscity a little better, it shouldn't be an issue.
Personally though, for my truck, I run synthetic and I just treat it like regular oil. Call me anal, call me quirky, call me potentially throwing good oil away, but that's just me I guess.
I tried running Mobile 1 longer on both of my trucks this year.
I put on about 7k per year on each vehicle. Not a lot of miles.
I just changed the OEM oil filters last weekend as it's been 6 months (3k miles since the last oil change) and the T100 oil was substantially darker than the 4runner. The T100 has 110k miles and is a 95 compared to the 4runner having 67k miles and being a 99.
I'm a little concerned with the darker oil on the T100. The 4runner oil is barely darkened compared to the fresh color from a new bottle.
I'll try the Mobile 1 filter or Amsoil filter on the T100 at my next interval and see what the difference is.
Old 03-12-2006, 05:41 PM
yota4me2's Avatar
I'd caution you to make sure you're getting the new version M1 EP filter. The ones I've seen are black and have 99.2% multi-pass efficiency rating on the box. The older version filters are substantially less efficient--not good for longer engine life.
Old 03-12-2006, 06:05 PM
  #25
yota4me2's Avatar
To me, the darker oil indicates the synthetic oil is cleaning a dirty engine. I'd be reluctant to go over 5k miles with the darker oil. You could clean the engine with Auto-RX (highly recommended on the BITOG site). I'd follow the instructions strictly. I wouldn't do extended oil change intervals with anything less efficient than the new version M1 EP oil filter. The M1 EP oil is better than M1--substantially more cleaning & anti-wear additives. I'd recommend the Amsoil EA air filter if/when available--substantially more efficient than a paper filter.
http://www.amsoil.com/StoreFront/eaa.aspx
Old 03-12-2006, 08:05 PM
  #26
mach4's Avatar
yota4me, thanks for the pointers.
The auto-rex treatment seems like a very good idea.
The T100 was on dino castrol gtx prior to me purchasing it a couple of years ago. This truck is in very good condition and lightly used at about 10k miles per year. This is an eye opener for me to see the effects of dino oil over the long run.
Old 03-21-2006, 07:31 AM
  #27
BruceTS's Avatar
Originally Posted by paddlenbike
I just bought the TrueFlow airfilter from Jason B. Wish it were included in the test.
"- Great filtration – filters down to 3 microns"
Old 03-21-2006, 09:35 AM
  #28
yota4me2's Avatar
Interesting/informative air filter comparison test (Trueflow vs. paper vs. gauze):
http://truckworldtv.tenmagazines.com...lid=863&sid=88
The Trueflow looks like an improvement over paper air filters. However, Amsoil claims the Amsoil EA air filter is 5 times more efficient than a paper filter at .8 microns. .8 vs. 3 microns (for Trueflow?)--so it looks to me like the Amsoil EA air filter would be the most efficient. I'd go with Amsoil EA air filter if/when available.
Old 03-22-2006, 06:55 PM
  #29
cheap sunglasses's Avatar
Does anyone know the part number for an AMsoil air filter for a 22re? (EFI)
Old 03-22-2006, 07:09 PM
  #30
yota4me2's Avatar
Not available for 1985 22re. Check here for other year models:
http://www.amsoil.com/scripts/runisa...msoiloaf:index
Old 03-23-2006, 04:17 PM
  #31
thanks man
smthwsn357
05-01-2024 07:28 AM
Eggslinger
06-08-2019 03:32 PM
taller1
07-16-2015 03:00 PM
nick b
07-11-2015 04:38 AM
wilbertd
07-06-2015 07:39 AM
Quick Reply: Best filter for max engine life
