Anyone know how the A340 figures out when to shift?
if you notice in the video the torque converter is not locked up. that is the reason for the slugish shifts. Bet if the TC was locked up the shifts would have been a hell of alot crisper. I
As for your shifting problem, I am much more familiar with the A340 in the Jeep applications which use a seperate TCU and sensors, but most shifting problems with those are traced to the TV cable beng out of adjustment or a faulty TPS. Just some thoughts for you.
Straight forward to swap
Solenoids for a340h
Axiom Automotive Technologies, Inc.
1360 Incleside Road
Norfolk, VA 23502
(800) 622-6997
solenoid kit: #97420K a340E/F & H
Very nice on the phone and quick to deliver.
It took me 3hrs to: drain the tranmission fluid, drop the pan, remove the "lower part" on the inside of the transmission, replace the 4 solenoids, put the "lower part" back on, put in a new filter, put the pan on, attach the transmission dip stick, fill with transmission fluid, and start up to check fluid leve.
1360 Incleside Road
Norfolk, VA 23502
(800) 622-6997
crashburnoveride
Jul 10, 2015 06:39 AM
