Anyone in CO. seen this tire carrier?
Old Mar 27, 2006 | 08:57 PM
1985 4Runner's Avatar
Question Anyone in CO. seen this tire carrier?
I saw this tire carrier & think it might be a great solution to carrying tires up to 49" (claims the manufacturer)
Anybody out in Colorado seen this or know of the shop? From the pictures, I assume it could be mounted on a few aftermarket bumpers. Any of you fabricators got an opinion?
Check out the link:
http://colorado4x4.org/vbb/showthread.php?t=59255
Old Mar 29, 2006 | 07:44 AM
Anybody like the carrier?
Old Mar 29, 2006 | 09:07 AM
RED 85's Avatar
I have not seen the bumper but do know the shop and owner and are stand up guys. i would give them a call and see what they can do for you.
B
Old Mar 29, 2006 | 10:18 AM
Thanks Red 85, I was looking for a way to carry a 39.5 Bogger & this might be what I am looking for. I have heard some bad things about the swing out arms of bumper mounted rear carriers cracking welds and such on large tires/rims.
Old Mar 30, 2006 | 05:49 AM
westy44runner's Avatar
I think its a good design, much stronger with 4 mounting points rather than a single point. The only downside I can see is being it might be in the way when it folds down when you need to access items from the rear, but probably not a huge issue and worth not having all the problems associated with those single spindle design bumpers.
Old Mar 30, 2006 | 05:59 AM
FilthyRich's Avatar
that is VERY trick and well designed..
Seems that would be the way to go with a huge spare
Old Mar 31, 2006 | 08:51 AM
99_Runner's Avatar
Very interesting design. I think that it would work really well.
Old Mar 31, 2006 | 09:22 AM
I would maybe consider buying one if someone in Colorado had actually seen the product up close & thought it was a good buy.
Old Mar 31, 2006 | 10:01 AM
Good Times's Avatar
damn i really like that design!! hmm... maybe I can modify mine since I need to redo it
Old Mar 31, 2006 | 10:28 AM
Intrepid's Avatar
Seems like a lot of effort and probably a lot of money for a tire to still be right in the way when you need to get to the back of the truck. I mean, trying to get the top off my runner by myself is a real pita anyway, nevermind with a massive tire and carrier in the way. Cool design though. Too bad they couldn't make it with the same design but have it swing sideways or something.
Old Mar 31, 2006 | 12:03 PM
I think the whole point of a new design was to get away from the swing out design. Also the tire is lower to the ground when folded down, for easier removal/installation of the tire. I know I hate trying to lift a 39.5 bogger by myself, a real PITA, I have to have help.
Old Mar 31, 2006 | 12:07 PM
Good Times's Avatar
My only concern is still raising that tire. won't it still be dead weight trying to raise that sucker? I've got 35's and it's a PITA already on my bumper/tailgate design so I'm having some thoughts on how I want to redo mine.
Old Mar 31, 2006 | 12:36 PM
tc's Avatar
tc
It's got air springs (like the lifts used for rear hatches) to offset the weight.
Old Mar 31, 2006 | 03:59 PM
Well I have to call these people, maybe I can get a bumper/carrier combo price. I sure am liking this one more & more.
Old Mar 31, 2006 | 05:10 PM
RED 85's Avatar
As soon as i can get some time i will go and talk to Chris, and if he needs a rig to mock up what you want i can take mine down there and have him do it off mine.
That is the owners rig that is on and i can take a look at it then, he also works with a mechanical engineer so i am sure that it is pretty sound.
B
Old Mar 31, 2006 | 06:02 PM
B
Cool, I will get some pics of my frame/bumper & take some measurements tomorrow. Thanks!
I will measure my current bumper to see if it will fit, if not it will have to be cut off, as it is welded on.
Old Apr 1, 2006 | 09:38 PM
DrBeau's Avatar
My biggest concern with this thing is rear access, especially if you have a 3rd or 4th gen 'Runner (which the hatch). If the design could be worked out so that you could still use the rear area, it would be awesome.
This is all assuming you use the truck in a somewhat expeditionary style. If I had a trail truck/buggy type vehicle, this might be the way I'd go.
Old Apr 2, 2006 | 09:08 AM
tc's Avatar
tc
Fellas - keep in mind this is for BIG tires. If you're riding on 40's, you'll probably not have great access to the rear cargo area anyways. The tire rack may actually make a decent step to HELP with the access in these tall trucks.
Old Apr 2, 2006 | 01:44 PM
That is why I am interested in this carrier, I am looking to mount a 39.5 Bogger. Now I gotta get those measurements....
Old Apr 2, 2006 | 02:06 PM
wrenchmonster's Avatar
Humm, overall a great idea. I've pondered this problem myself and was thinking about building a swing away style, but mine would have some engineered strength built into it for the weight. I was thinking coming off the bumper in a triangle or 3 sided pyramid, so instead of having a single post which often bends, have a triangle with the post in the center. Then there would be esentially a pipe riding around the center post slightly offset for bumper clearance, which rode on some torrington bearings to handle the weight of the tire.
For the tire, I wanted to develop a kind of elevator lift. So the tire assembly would ride straight up and down on a geared track for lowering and raising. Kind of like a high lift jack, but more of a geared mechanism that moved smoothly up and down. With a little gearing, even a weakling could raise and lower the biggest of tires. You could have a handle that installed right through the tire. Think of a hand started car or tractor.
In any case, that was my idea. I'm probably not doing a good job describing it, I'd be happy to elaborate if anyone was interested.
