Any experts at shooting paint on a budget ?
Old May 15, 2006 | 09:43 AM
nrgetic99's Avatar
I am thinking about having a go at painting the chrome bumpers on my 98 Limited.
I have found some good tech articles on how to paint chrome but as I have a compressor (25 gallon, 6 cfm @ 90psi ) I was wondering if I have enough cfm to be able to do some limited painting ?
Anyone have a cost effective set up ?
Thanks
David
Old May 15, 2006 | 09:54 AM
snap-on's Avatar
ive shot a few (small) things on my HF 2 gall pancake with my smaller touchup gun.
Old May 15, 2006 | 10:14 AM
nrgetic99's Avatar
You sir, are a rockstar
David
Old May 15, 2006 | 10:23 AM
JuttyShabango's Avatar
You normally don't worry about the CFMs and should be using a Low Pressure, Hi Flow gun that feeds from the top.
Paint is easy to do, it's the prep work that gets most people. Use a quality primer and a decent paint.
Lay it in light layers allowing the paint to completely dry or "tack' before shooting another coat.
Use lots of fans to keep the overspray away from your paint.
Lots more to it, but that's the basics. Also, paint on the X Y Axis to get a consistent coat and seal it with clear
Old May 15, 2006 | 11:01 AM
nrgetic99's Avatar
Great info.
Prep should not be too bad...I am very patient and a bit of a perfectionist.
Can you give me a couple more tips on the use of fans ? I am going to screen off the end of the garage with plastic sheet. SHould I use the fans to suck the air away from the piece or blow air over it toward the opening ?
I have a respirator.
Thanks a agin,
David
Old May 15, 2006 | 11:07 AM
Originally Posted by nrgetic99
Great info.
Thanks a agin,
David
Use the fans to pull the air away from the object. You should be able to shoot some spray and see it travel to the front of the vehicle. Cleanliness is next to Gawdliness when its paint.
I have a couple furnace fans hooked up to a motor..but be careful with this set up as fire could result if motors are hot and alot of paint in the air. If this is the case...simply put a furnace filter infront.
One of my very good friends has a booth in his shop and does paint on the side.
Old May 15, 2006 | 11:14 AM
nrgetic99's Avatar
Cool, I have a huge box fan and was going to rig a shroud. I will use an a/c or furnace filter.
David
ashamsuddin
17
Jul 22, 2024 03:59 AM
ladybugRC
458
Aug 21, 2020 10:41 AM
TheBFA
Feb 15, 2020 06:55 AM
bradahman
Oct 1, 2015 09:24 AM
charlie_fong
Sep 27, 2015 10:06 PM
