alternating blinkers
Old Nov 11, 2006 | 07:50 PM
drguitarum2005's Avatar
From: Houston (home), Atlanta (school), Cincinnati (work)
ive seen a post or two somewhere where they wired up the corner bulbs to blink when the stock turn signals (in the bumper/fender) are out, giving an alternating effect. does anyone have any more information on how to do this? ive seen it somewhere but i cant find it now, im not sure what to search for for that i guess.
Old Nov 11, 2006 | 07:54 PM
Elton's Avatar
i wouldint mine doin that mod
Old Nov 11, 2006 | 07:58 PM
Corey's Avatar
Co-Founder/Administrator
I believe both Roger Brown and Chris Geiger pioneered this mod long long long ago.
It is around the 'Net somewhere.
Old Nov 11, 2006 | 08:59 PM
KyleT's Avatar
you can also flip the wires to make the corner blink off when the lights are on, and blink on when they are off.
Old Nov 11, 2006 | 09:42 PM
can you elaborate on this? i dont think i understand what you mean
Old Nov 12, 2006 | 06:27 AM
Yoda's Avatar
You disconnect the ground wire for your front marker light and connect it to the power wire for the front turn signal light,
If your lights are on, it will flash alt with the TS, if lights are off, it will flash in synch. A certain American car company whose initials are GM has done this for years. Others have also, but GM was the first I remember.
Old Nov 12, 2006 | 06:58 AM
AH64ID's Avatar
I would also think that thru some relays you could do this also...
If you add a realy to the ground (IIRC toyota uses switched grounds) that uses blinker power to open the normally closed circuit you would turn the marker light off when the blinker is on. This method would only work with the parking lights on.
It seems it should be able to be done easier, but the only thing I can think to do to get this to work when the parking lights are off would be to get power before the flasher relay, then use a realy that is normally closed and when the normal blinkers are the ground will open the realy and turn off the parking lights when the blinker is on.
Yoda, I dont understand what hooking a ground wire to power wire would do, other than probally blow a fuse???
Old Nov 12, 2006 | 07:48 AM
Yoda's Avatar
You don't ground the T/S power wire, you connect the marker ground wire to the T/S power wire. So, when the park lights are on, the marker is grounding through the T/S filament. Then, when the T/S is on, the ground is lost, and the marker goes out
Here is a link for this mod on a *atsun
http://dimequarterly.tierranet.com/a...tech_lite.html
It does not work if your side lights are grounded through the light housing
SAFETY NOTE! If you don't know what you are doing, don't attemt this.
Old Nov 12, 2006 | 08:07 AM
AH64ID's Avatar
Okay yeah that makes more sense.... but i wonder if it works with a switched ground, or if toyota even uses a switched ground...
Old Nov 12, 2006 | 10:17 AM
KyleT's Avatar
yeah somehtign like that, i have a VW wiring diagram here somewhere that I was cheating off of, ill try and dig it out i guess.
shooter86314
Jan 7, 2016 07:05 AM
Chicken12
Oct 14, 2015 03:54 PM
Scotttekoch
Sep 28, 2015 10:30 PM
fountain
Sep 28, 2015 03:04 AM
SCZIG
Sep 20, 2015 09:00 AM
