Aisin manual hub problem.
Old Jul 29, 2009 | 02:26 PM
nevermore1701's Avatar
Followed Wabfab's guide, was easy enough. Once I got it all back together though, the CV still spins in both free and locked positions. It all looks put tgether right, and everything fits well, it just won't spin free in free mode. What am I doing wrong?
Old Jul 29, 2009 | 03:09 PM
waskillywabbit's Avatar
Try that again as you are contradicting yourself it seems.
Old Jul 29, 2009 | 03:12 PM
Everything installs easily, but wheni spin the tire, the CV axle spins with it regardless of if the hub is locked or free.
Old Jul 29, 2009 | 03:14 PM
Clutch is not moving with the big spring correctly. Check and make sure you didn't use too much grease and that the spring isn't on backwards. Flat side goes in the clutch.
Old Jul 29, 2009 | 03:18 PM
Pring is correct, I'll try lightening up on the grease.
Old Jul 29, 2009 | 03:20 PM
If you have too much grease it will create a suction and the clutch won't move. Just enough grease so there is a light coat, like a glaze on a cake, not like icing on a cake.
Old Jul 29, 2009 | 04:59 PM
Ok, stripped almost all of the grease, same thing, on both of them. I triple checked, the springs are on correctly, and seem to have good compression. Is there anything else I could be missing?
Old Jul 29, 2009 | 06:02 PM
Messed with them some more.
When the dial/face/clutch/springs are put together, one will turn from free (cluch up against face plate) to lock (clutch extended away from face plate) using the dial. On the other one, the clutch stays in place when you rotate the dial. You can turn the clutch assembly itself and it will go from closed to extended, but turning the dial doesn't do it. When they're all assembled into the hub, neither of them work, even the one that seems to do OK when taken out. The CVs still spin, no matter if they're in lock or free position.
Old Jul 29, 2009 | 06:12 PM
jpmountainboy's Avatar
make sure your spring hook end is set where it gets pulled when actuating the "clutch". you have to hold the gear with your palm when testing so the gear doesnt twist, then install it in closed/free mode. i had this very same problem...those little things are actually a bit tricky, just look at all the small stuff and make sure it all makes sense...it took me a little bit when rebuilding mine to get it all right. the first time it pushes in and pulls out is always a little reluctant. spin the wheel backwards to get it to unlock if it wont.
good luck
Old Jul 29, 2009 | 06:19 PM
I'm fairly sure I have them together right, and that one seems like it should work....
I read through about a half dozen walkthroughs, with pics, I'll see what I think tomorrow.
Old Jul 29, 2009 | 06:28 PM
Did you just refurbish ones already on your truck or swap them out from ADD or auto hubs?
Old Jul 29, 2009 | 06:30 PM
Swapped them with the ADDs that were on there, it's a '95. I got them from a guy on here, he said he rebuilt them, and they look brand spankin' new, clean as a whistle. No rust or even discoloration.
Old Jul 29, 2009 | 06:32 PM
Should be a direct bolt on so something with the hubs is not put together just right.
If you can't figure it out, might take some pictures of how you got them put together. They got to be just so.
Old Jul 29, 2009 | 06:33 PM
Mkay, I'll try to get some pics tomorrow.
jaretstuff
Aug 4, 2015 02:08 PM
Steven.m.paulk
Jul 24, 2015 01:44 PM
MTLroadierunner
Jul 20, 2015 03:07 PM
PlayAwhile
Jul 20, 2015 11:36 AM
ItsJustD
Jul 7, 2015 07:49 AM
