Accidental redline from startup. Any damage?
Old Feb 28, 2022 | 04:51 AM
LunarRunner's Avatar
Have a new 4Runner with about 3000 miles on the engine. I was planning to change the oil at 5k miles and was reading up about pre-filling the oil filter. I had read that some cars have a clear flood mode where you can hold down the accelerator and start the engine and it will cut off the fuel and just crank the engine via the starter to build oil pressure. Like a fool, I decided to try this rather than verifying this was a feature. Turns out, 4Runners don’t have this feature and I essentially redlined my engine straight from startup. I’m concerned because I doubt the engine could have built oil pressure fast enough to provide enough lubrication. I had driven my 4Runner 3 miles prior (about 10 minutes operating time) and parked it while I ran into a store. It sat for about 20 minutes and then I tried starting it with my foot pressing the gas all the way to the floor and that’s when it started and went straight to redline. I’m hoping the short trip I took was enough to get the engine coated with oil so even if it had zero oil pressure during redline, enough residual oil was on the internals to prevent wear. What do you all think?
Old Feb 28, 2022 | 06:54 PM
Discombobulated's Avatar
Nah, I wouldn’t worry about it. My 22re that’s 31 years old from a cold start when it’s 0 degrees out accidentally redlining…..eh I probably still wouldn’t worry
TheWiz
Dec 30, 2021 07:01 PM
ET
Feb 4, 2012 09:14 AM
Cwaters1184
Sep 29, 2008 04:19 PM
knaffie
10
May 11, 2005 06:10 PM
phorunninduke
Jan 6, 2005 06:33 PM
