24R-GTE Tech
Old May 1, 2007 | 09:16 PM
Bunta Fujiwara's Avatar
24R-GTE Tech
Here is the 24R-GTE torque curve:
sorry about the bad quality, you'll be able to download it if you wish from my website within a few days.
Red is lb-lbf., and gray is bhp.
as you can see, bhp is very peaky, and torque is flat compared with existing Toyota engines. (in comparison to max. RPM). It peaks around 11,800. Max. RPM will be 12,500.
Old May 2, 2007 | 06:21 AM
ewong's Avatar
12,500 eh...
sounds more like a motor for raceing in Akina wit ALOT of tofu than a "truck" motor... would be fun tho
One of the NICE things abotu the stock 22RE and the W56 trans is it appears designed so that when driving int he "hills" as you slow down the peak torque CLIMBS... i.e. you down shift in the hills and run the motor at say 3500 rpm but peak torque is at 3000 so that as you "slow down" the torque climbs - allowing you to maintain speed in the hills.....
Old May 2, 2007 | 11:25 AM
NaeSLaS's Avatar
that would SCREAM on a trail...you'd have to get it up to 8000rpm before it'll move the truck....toasted clutch anyone? LOL
Old May 2, 2007 | 01:37 PM
norcalsvx's Avatar
id just swap a 13b in and call it a day
Old May 3, 2007 | 10:41 PM
In actuality, the engine will make over 100 lb-lbf. by 2000 rpm and over 200 lb-lbf. by 5200 rpm. The curve I posted is not the final version. The torque curve is flatter than that. Power is very peaky, but still more than adequate for a Toyota truck, even below 5000. It's made so you could drive it exactly the same way as you drive your current yota.
MadMax48
Mar 3, 2020 10:33 AM
ToyotaMD
Aug 17, 2018 10:16 PM
