22 re diagnostics help
Old Feb 17, 2009 | 01:41 PM
crathey89yota's Avatar
I installed an LC header and K&N intake. Sometimes the motor runs really rough and sluggish. Are there some tuning issues I should be thinking about? Or do I need to hook up a scanner and clear codes?? I'm not sure what is causing the problem but before the mods I never had this issue. Please help!
Old Feb 17, 2009 | 01:55 PM
4Crawler's Avatar
Should not need any tuning, might be a problem with the O2 sensor if you are using an aftermarket one that is too short on the sensing tip. Read the codes, it is trivial to do:
- http://www.4crawler.com/4x4/CheapTri...CheckConnector
with this "code scan tool":
Old Feb 17, 2009 | 02:36 PM
muddpigg's Avatar
Pull codes and reset computer.
Old Feb 19, 2009 | 07:21 AM
Ok. I tried to pull the codes but when I used the scan tool the CEL stayed on and did not flash any codes. I went ahead and reset the computer but still same isssues.
some drunk guy
Aug 3, 2021 06:09 PM
calderp
Nov 16, 2015 02:49 AM
mulewright
Sep 28, 2015 10:27 AM
charlie_fong
Sep 27, 2015 10:06 PM
Boomer8404
Sep 24, 2015 01:12 PM
