2 Questions before heading to Alignment Shop
Swapped out some steering components and made some adjustments to pickup. Have 2 questions before getting it aligned.
1) Do I need to set torsion bars to stock setting before having alignment done? In other words, does it affect the alignment? If I adjust them again do I need to get the truck aligned each time?
2) Is the front wheel base wider than the rear on a 94 truck? (mostly just curious), if so, by how much?
If you want your torsion bars set back to stock .
