1-3-5 shifting
Old Apr 21, 2010 | 01:42 PM
516593812's Avatar
1-3-5 shifting
when i'm on level ground (or even better- downhill) I often shift 1-3-5 & just skip 2&4. Or, I'f im on a downhill start, i'll start in 2nd & just go to 4th.My truck drives great, clutch is good, & i always make sure the engine is spinning fast enough (i make sure i'm not lugging the engine) My theory is that it puts less wear on my gears & my clutch, possibly even uping my MPG.
so am i doing any harm in the long run? what adverse side efects coudl i be causing? any extra wear? if so, on what parts?
Old Apr 21, 2010 | 01:50 PM
2DoorRunner's Avatar
Seems like faulty logic to me, but im no expert, so i will see what everone else says
Skipping gears and starting out in 2nd will wear your clutch more though.
Old Apr 21, 2010 | 07:01 PM
Matt16's Avatar
You're wearing out the clutch a lot more. Considering clutches are a wearable part and transmissions usually last longer than the engine (so basically they outlast the truck) you're only increasing your cost of ownership.
Also, you're not saving any fuel by using fewer gears. The engine is designed to operate in a narrow powerband, strecthing that powerband to stay in gear longer is only hurting the engine and your fuel consumption.
Bad idea.
What you want to be doing is accelerating just slow enough to piss off the people behind you, that's how you save fuel. Try to use the right gear so you stay around 1500-2200rpm with the accelerator barely depressed.
Old Apr 21, 2010 | 07:04 PM
Yeah i have been driving between 2k and 3k rpms and i have saved quite a bit of gas. I wouldnt even skip gears if i could. My worn out 22re wouldnt like it much.
Old Apr 21, 2010 | 08:48 PM
wyoming9's Avatar
Red face
I have done this all the time as you state you are not putting undo strain on the clutch.
I don`t know if you will save gas maybe.
When you drive a manual trans long enough you know when you can get away with skipping gears
to each there own
Old Apr 21, 2010 | 08:49 PM
Swimmerboy2112's Avatar
Bad idea.
You said it perfectly!
Old Apr 21, 2010 | 08:53 PM
Teuf's Avatar
use the Gears, ya clutch n motor likes it that way.
Old Apr 21, 2010 | 08:56 PM
Teuf's Avatar
try that on a bicycle, see how you feel.
Old Apr 21, 2010 | 09:27 PM
survivorman97's Avatar
I like this...
But yeah I am for not skipping gears really. Seems that low rpms dont really save you that much fuel is you are just having to push the pedal down more to get the same ultimate result. But like the down hill rolling starts in second I think those are fine and will save you a little being that you only use 1st up to like 10mph anyways, if gravity will do the first gears speed for you, let it.
Old Apr 22, 2010 | 08:19 AM
516593812's Avatar
cool. thanks all. points taken.i think i'll stop skipping gears- except when i'm starting/ going downhill. when i do shift 1-3-5 on level ground, i don't press the gas pedal down any further than normal, i just keep it in gear longer, before i shift up.
Old Apr 22, 2010 | 10:55 AM
Matt16's Avatar
DOwnhill is fine- gravity is doing the acceleration.
Old Apr 23, 2010 | 03:24 PM
stormin94's Avatar
So you have 5 speeds, but you only use 3 of them......
Old Apr 23, 2010 | 05:28 PM
Peach's Avatar
I Like this for some reasone
Funny
Old Apr 24, 2010 | 12:05 AM
wyoming9's Avatar
Red face
What about a 13 speed or 15 with double overdrive with 600 horse power would that be bad to skip gears also.
Old Apr 24, 2010 | 02:49 PM
stormin94's Avatar
Empty or loaded?
punks_is_4x4
Feb 26, 2016 04:29 PM
Davebarbier
Nov 3, 2015 03:28 PM
Flightguy
Oct 2, 2015 05:34 PM
kbpickens
Oct 2, 2015 03:37 PM
creecher10
Sep 30, 2015 03:27 PM
