Sponsored by: CARiD
will a 1992 toyota axle shaft fit into an 84?
Old Nov 16, 2012 | 06:23 PM
nedhills's Avatar
my question is exactly what the title says, will a 92 toyota pickup axle shaft fit into a 84 pickup?
Old Nov 16, 2012 | 06:24 PM
toyota4x4907's Avatar
No...
Old Nov 16, 2012 | 06:30 PM
moutainman4life's Avatar
the 92 is longer they made the rear ends wider in 86 you can use one from 79 through 85
Old Nov 16, 2012 | 06:50 PM
rokblok's Avatar
Yours is a solid axle front. As was stated, 79-85 solid axle parts work for you. In 86 they went to IFS front (in the States) so to match the necessary width of the new IFS fronts, they went 3" wider for the rear diff. It's a common upgrade for us early solid axle guys. IFS rear diff assembly offers more stability and bigger drum brakes. In my case, everything bolted into my 84. Just get the IFS leaf spring U-bolts if you get one from a yard. The diff tubes are a bit larger in diameter.
Hatch man
Aug 25, 2021 12:54 PM
6th Gear
19
Dec 10, 2019 07:31 AM
RaginAsian91
Jul 27, 2015 07:11 PM
irish_tyrant
Jul 6, 2015 11:22 AM
abalagtas
Jun 22, 2015 12:57 PM
