Sponsored by: CARiD
Why does my FL axle break so quickly?('90 pickup)
Old Apr 4, 2010 | 05:54 PM
Motorider's Avatar
That picture is exactly what I needed to see. Thank you.
So I am thinking I need to install four total 4"-compression-bumpstop-extenders, since there are two compression-bumpstops on each a-arm of the truck? Meaning two 4"-compression-bumpstop-extenders on the drivers side, and two on the passenger side? And leave the one rebound-bumpstop on each a-arm in stock position?
I can tell now that this should have been done when the lift was installed.
Would just getting on the gas in reverse(4-low) be enough force to cause the suspension to travel farther than it should? The shocks seem fairly new. When the axle went out the second time, that was all that was happening, and I think the tires were even pointed straight. Just getting on the gas doesn't seem like enough force to bottom the suspension farther than if I had the bumpstop spacers installed.
Old Apr 5, 2010 | 08:31 PM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
have a look at the pics in this thread... https://www.yotatech.com/forums/f116...n-help-208926/
Colington
Mar 8, 2020 09:51 AM
jerusry
Oct 19, 2015 05:28 PM
ItsJustD
Jul 7, 2015 07:49 AM
skoti89
Jul 6, 2015 07:45 PM
toyoda8488
Jul 5, 2015 10:18 PM
