Sponsored by: CARiD
wheel felll off and lug holes on aluminum rims are elongated
Old Aug 29, 2010 | 07:08 PM
gary96360's Avatar
hey there i bought i set of eagle alloy rims on 33's l last week aand istill have to get thembalanced.so a tirefalls off and rolls past me last night. i put the wheel back on the truck and i see the lug holes are oval shaped. i can still centre the rim with the tapered lug nuts but can the tire stil be balanced? i will have to get taped on wheelweights. thanks
Old Aug 29, 2010 | 08:10 PM
dropzone's Avatar
Fossilized
Sounds to me like you failed to properly torque the wheel when you put it on.
The wheel is shot IMO.
Old Aug 29, 2010 | 08:12 PM
2DoorRunner's Avatar
Yep, time for a new wheel, and maybe even new wheels. Either you didnt tighten them enough, or you used the wrong lug nuts.
Live and learn.
Old Aug 29, 2010 | 08:36 PM
brian2sun's Avatar
x3. Don't kill yourself over a wheel.
Old Aug 29, 2010 | 08:54 PM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
I thought all new aluminum rims required a periodic re-torquing so the sleeves can get tamped down...
Vary common problem. If aluminum...
That and "knock off" spindles reversed so torquing spins them off, instead of tightening ask me how I know... No don't!
Old Aug 29, 2010 | 09:00 PM
Your balancer guy will tell you if it's warped or not...
If it comes up to like 10oz. that's a TON in wheel weights, and it's warped...
And they make clip-ons for aluminum too, and you can set a balancer to only put them on the inside.
And yeah, x2 on 2door4runners post... "i can still centre the rim with the tapered lug nuts" Makes me think your using your original lugs...
See SR5 lugs. They're made to go into the lug hole.
Old Aug 30, 2010 | 04:50 AM
waskillywabbit's Avatar
Throw that rim away and buy another. It is ruined.
Old Aug 30, 2010 | 11:35 AM
maistroyoda's Avatar
You should just replace it as it is not worth an accident. That happened to me a few years ago when a buddy was helping me put the wheels back on my Altima. I assumed that he had tightened and centered the wheel properly. The wheel was toast and I could not find the discontinued style anymore. That really sucked but lesson learned. Double check your buddys work.
Jun 1, 2021 01:51 PM
chukarhunt
Dec 8, 2019 11:39 AM
94yotaMI
Jul 21, 2015 05:47 AM
Yotoder865
Jul 9, 2015 07:51 PM
