Sponsored by: CARiD
what size wheel spacers? without longer studs
Old Jan 6, 2012 | 01:01 PM
creswellhick's Avatar
so i looked around for this but cant find much and im on my phone to so its my 84 it rubs on the drag link at about full turn im pretty sure and i dont have the cash for high steer since ive been laid off fer awhile and aint haven luck back to the subject so wats the biggest spacers i can get or wat size should i get without having to get longer studs
and whats the cheepest place for spacers cheapest i found was like 80 bucks sorry fer the long post and run on sentence any other suggestions on wat i could do would be sweet
Old Jan 6, 2012 | 01:09 PM
Outsane's Avatar
how much space do you need?
I have a set of 10mm spacers I used with out issue, I can sell..
If you need an inch or more then you will not need longer studs. since your rims will be on a new set of studs..
http://www.wabfab.org/Featured-Produ...ypage.tpl.html
Old Jan 6, 2012 | 01:14 PM
i honestly dont know how much i need maybe inch or inch and half
Old Jan 6, 2012 | 01:15 PM
Outsane's Avatar
your studs will go into the spacer, put on some lug nuts, then your rims mount to the studs on the spacer, and put on another set of lug nuts
Old Jan 6, 2012 | 01:18 PM
cool how wide are yours in inches .... maybe i can find some cheaper ones then 85 bucks would be sweet
Old Jan 6, 2012 | 01:50 PM
Outsane's Avatar
mire are less then1/2 inch... your going to need real spacers like the ones in the link
Old Jan 6, 2012 | 02:01 PM
ya i figured jus didnt want to have to spend that much but ill look into some more see if i can find some others
Old Jan 6, 2012 | 06:38 PM
waskillywabbit's Avatar
Wheel spacers that have their own wheel studs in them start at 1".
Best way to see what you need is to measure how much clearance you'd like and start from there. I don't put less than a 1.5" on anything and typically use it for everything.
:wabbit2:
Old Jan 6, 2012 | 09:26 PM
thanks wab ill probally go with 1.5 or 2 ill measure tommorow
coffey50
Jul 28, 2015 10:55 AM
terminator
Jul 27, 2015 07:13 PM
Gravel Maker
RuffStuff
Jul 27, 2015 06:53 PM
whereAreMyPants
Jul 22, 2015 03:32 AM
Yotoder865
Jul 9, 2015 07:51 PM
