Sponsored by: CARiD
What should happen when I pull the EFI fuse?
Old Jul 24, 2007 | 06:26 AM
DaveB's Avatar
Hello from Waterworld!! ... sorry England
Right I have a 97 Yota Colorado Prado 2.7 Litre petrol (3RZ FE) that is running like a stricken pig at the moment.
Starts first time, then dies after 200 yds at the first stop sign, turning over sounds like its flooded?? then fires starts once warmed up runs OK again.
I have checked everything I can think off and read a discussion about reseting the Engine management unit. So I pulled the EFI fuse as suggested.
Afterwards, the engine was almost impossible to start, lumpy, backfiring slightly, but seemed ok once warmed up, Im begining to suspect the EMU is at fault any of you guys had any experience of this ??
Any suggestions are greatly appreciated.
Dave
Old Jul 24, 2007 | 06:55 AM
snap-on's Avatar
im going to start with spark probs....
any CEL's ?
check replace the simple stuff first, plugs, wires, cap, rotor. there are some simple diagnostics for the ignitor, check timming
Old Jul 27, 2007 | 12:35 PM
thook's Avatar
Hello Dave,
Try looking at your fuel pump relay, also.
Old Jul 27, 2007 | 12:38 PM
drguitarum2005's Avatar
From: Houston (home), Atlanta (school), Cincinnati (work)
when you pull the fuse, it should just start sputtering then die. if you try to start it with the fuse out, it will crank, it might start but run real rough (depending on how long the engine ran with the fuse out), but likely it just wont start.
Old Jul 27, 2007 | 12:44 PM
WATRD's Avatar
You are probably driving it on the wrong side of the road. Try changing sides and see if that helps.
*Sorry!* I had to get that out of my system
In my experience, the onboard computers seldom cause problems like you are describing. Either they are working fine or they don't work at all and the rig won't run at all.
What you are describing sounds more like a sensor problem. MAF, etc.
Old Jul 27, 2007 | 03:02 PM
86toysr5's Avatar
any CEL's ?
not tryin to hijack but my 97 tacoma was my in may 97 so it wasnt the 98 model yet but i dont have cap and rotor....its coil packs
oldirtydirt
Feb 23, 2020 09:30 AM
skoti89
Sep 11, 2015 07:46 AM
rushw
Jul 18, 2015 01:46 PM
Sandman
Jul 14, 2015 12:36 PM
dpridgeon3
Jul 9, 2015 01:18 PM
