Sponsored by: CARiD
Warm Crank
Old Mar 13, 2018 | 06:13 PM
JRP's Avatar
JRP
Warm Crank
Hello I am new to Toyota, I just got a 1995 pickup 4x4 ext cab, 22re. So far I love it, it rides and drives great, but after a warm shutoff it doesnt want to crank up too good, around the little butterfly on the intake is clean, any suggestion? thanks
Old Mar 14, 2018 | 01:58 PM
wyoming9's Avatar
Red face
It will always start good cold ??
But cranks forever after running ??
Once up to Temperature if you turn the engine off and restart right away will it start or do you get the long cranking??
My first Guess would be leaking injectors fouling out the plugs
What do your plugs look like??
Old Mar 14, 2018 | 02:16 PM
old87yota's Avatar
Originally Posted by JRP
Hello I am new to Toyota, I just got a 1995 pickup 4x4 ext cab, 22re. So far I love it, it rides and drives great, but after a warm shutoff it doesn't want to crank up too good, around the little butterfly on the intake is clean, any suggestion? thanks
Welcome to the Toyota family.
What exactly do you mean by the truck doesn't want to crank up too good?
Does the engine crank just fine but does not start after it warms up OR does the truck have a slow or no crank after it warms up and you try to start again?
Old Mar 14, 2018 | 05:20 PM
RAD4Runner's Avatar
Welcome to the forum, JRP!
Pls put us in front of your engine compartment:
Good job describing your rig. However, transmission type is also a critical information. I suggest you out that information on your signature (model-year-engine-transmission-teim)
Please clarify:
  • CRANK = starter motor turning, hence, Cold-CRANKING Amps rating on battery- because battery is used to crank the starter.
  • COMBUSTION = spark + fuel + air. You hear, smell, feel the engine go "VROOM".
If Cranking problem,
Take picture of starter relay, socket where it plugs into, pin numbers and where they insert in socket.
Old Mar 14, 2018 | 11:10 PM
wyoming9's Avatar
Red face
I have yet to hear this VROOM sound??
Old Mar 15, 2018 | 06:27 AM
akwheeler's Avatar
Thanks for letting us know what truck you drive, but we need more information in order to help you. is it a stick or automatic? and your description is almost as vague as "I have a funny noise".
Old Mar 15, 2018 | 01:24 PM
RAD4Runner's Avatar
LOL! OK... a Purr like of a Prius
Old Mar 15, 2018 | 07:01 PM
thefishguy77's Avatar
You have just lost 10 internet points for the day.
5.9ford
Dec 6, 2012 05:20 PM
hermyboy3000
Aug 19, 2012 12:19 AM
92civeg
Mar 9, 2011 01:48 PM
92civeg
Feb 25, 2011 12:13 PM
az4x4runner
19
Dec 10, 2002 10:23 PM
