Sponsored by: CARiD
Want to swap out AT for MT, whats involved?
Old Mar 22, 2014 | 09:38 PM
pplusent's Avatar
Cool Want to swap out AT for MT, whats involved?
I have a 93 4runner that I would like to replace the AT with a MT. What is involved? Are the shafts the same? I am sure the mount is different, is there any problems changing out the foot peddles, Any problems mounting slave cyl, any wiring to worry about, etc.
Also I have found a 99 MT with only 125 mi on it for 500.00 and was wondering if it would fit behind the 3.0 v6, It came off a 3.4 v6.
Old Mar 22, 2014 | 11:39 PM
wyoming9's Avatar
Red face
With your 99 because it is OBII if you need to get emissions done .
The wiring can be a little interesting you need to do some repinning on your ECM other wise the MIL is on all the time.
You also have the neutral safety switch.
The rear drive shaft is different not sure about the front without double checking.
Running the hydraulics is pretty straight forward.
your really better off buying a complete parts truck other wise you will forever be running for something
Flywheel and clutch kit is a given.
Quite a few threads do some searching
Old Mar 22, 2014 | 11:50 PM
pplusent's Avatar
I got two engines with this 4runner and one had a manual flywheel, so I am good there.
I have found a guy on Craigslist parting out 4, 4runners so I can get a peddle assembly, mount, shafts and even a 93 Mt for 200.00, but no shifters.
The 99 MT is interesting because it is basically new, but I was worried the engine to trany bolt pattern might be different on the 3.4 engine, if it's not I might pick it up.
Old Mar 22, 2014 | 11:51 PM
pplusent's Avatar
Oh yeah, the slave cylinder. Is there a stamping on the firewall for mounting a slave?
Old Mar 22, 2014 | 11:56 PM
pplusent's Avatar
correction: I meant clutch cylinder.
Old Mar 23, 2014 | 12:19 AM
wyoming9's Avatar
Red face
Your slave cylinder mounts to the bell housing .
I just am drawing a blank right now on weather the holes are there for the master cylinder or if the need to be put in.
Old Mar 23, 2014 | 05:21 AM
Swimmerboy2112's Avatar
On the 3rd gens the holes are not there so I am assuming on this 93 you will also need to drill the holes.
Old Mar 23, 2014 | 04:27 PM
pplusent's Avatar
I assume the cyl mounts to the right of the brake booster and there are NO holes there.
I also assume the firewall is not thick enough metal to support the cyl and will need some sort of stiffener.
I will have to look at another 4runner to get the exact location for the holes.
Old Mar 23, 2014 | 04:46 PM
scuba's Avatar
What does emissions have to do with OBD2 and swapping a transmission?
OP:
You can use the 99 trans but you'd have to use the bell housing from a 3.0 manual trans and you'd also have to run a transfercase adapter so you can use a gear driven case and get the front output on the passenger side.
http://www.marlincrawler.com/transfe...-case-adapters
http://www.trail-gear.com/tacoma-transfer-case
Old Mar 23, 2014 | 05:14 PM
wyoming9's Avatar
Red face
well here in Pa if your MIL is on one does not get a sticker.
The condition causing the MIL to light must be fixed.
Which is fine if you never leave your own land.
If your OBD II vehicle has a automatic trans and you swap to a manual without repinning your ECM the light is always on.
So if the OP needs to pass it won`t that is what emissions has to do with swapping a transmission!!
Hence the statement if you need to get emissions done
jasonty
41
Dec 23, 2018 01:00 PM
jordyy
Aug 4, 2015 12:12 AM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
GeoRoss
Jul 24, 2015 03:03 PM
Nailit69
Diesel Swaps
Jul 21, 2015 05:28 PM
