Sponsored by: CARiD
Want to change 4 high to 1.1:1
Old Oct 14, 2009 | 02:59 PM
  #41
mastacox's Avatar
Originally Posted by YotaBob
I rotated the tire twice and the driveshaft moved just over 4 times.
Originally Posted by malteserunner
Sounds like you have a 4.10 then. Toyota's have low first gearing traditionally.
I agree, "just over 4 times" tells me you probably have 4.10's. 4.56's would have been 4.5 rotations, and 4.88's would have been almost 5 rotations.
... and hence the reason I said the odo was not a reliable way to go.
Old Oct 14, 2009 | 04:59 PM
  #42
YotaBob's Avatar
Well I went out there with my little chicken scratch sheet and counted 20 turns of the wheel and 40 turns of the drive shaft. I'm assuming I missed one turn of the drive shaft and it seems pretty conclusive that I have 4.10 gears. At 60mph on flat ground my RPM was @ 2200RPM +/- 50RPM
...Well ....back to the old 4.88 vs 5.29 debate
Anyone in western WA got an extra 4.88 I can throw in there for a couple days?
Old Oct 14, 2009 | 08:09 PM
  #43
g_cali's Avatar
Originally Posted by 4Crawler
Yep, speedo and odo can read differently, odo is most "accurate" in that is is 100% gear driven off the cable and simply counts revolutions. Of course it can be off with gearing/tire size mismatches, since it in effect counts drive shaft revolutions and not tire revs. The speedo is more prone to being off as it relies on a spinning magnet and a spring (in a mechanical speedo) to register a speed. On my '85 with 4.88 gears, I find the odometer is within 1% error with 33" tires but the speedo is off, have to drive nearly 70 on the speedo to go 65 miles per hour. But with 35s, the speedo is almost dead on and the odo is off (due to the larger tire diameter).
So with the 35's by how much is your odo off? I have 35's and 4.88's and according to the radar things they put on the side of the road my speedo is dead on. So just wondering if my odo is likely to be off as yours is?
Old Oct 14, 2009 | 08:15 PM
  #44
4Crawler's Avatar
Well, w/ 35s, the odo is off 35/33 or about 6% (i.e. it is dead on w/ 33" tires and so with 35" tires that are 6% taller is is 6% slow).
Test it on a mile marked freeway, most interstates have mile (paddle) markers and record your odometer reading as you pass one and drive 10 miles and record the ending reading. If you get to the nearest 0.1 mile on the odo you'll have your odometer reading to within ~1%.
Old Oct 14, 2009 | 09:24 PM
  #45
g_cali's Avatar
Oh yeah thats a good idea. Thanks man.
Old Oct 15, 2009 | 08:47 AM
  #46
tc's Avatar
tc
Yes, when somebody asks what is essentially the same question as has been answered a 100000000x, then I tend to assume they're not so bright.
But since this is the newbie section and I can't say "search ya newb", I'll sum it up for ya:
Toyota says 4.56 was the right gearing for 31's with a V6/MANUAL transmission so:
31 = 4.56
33 = 4.88
35 = 5.29
37+ = 5.71
For a V6/AUTOMATIC, they said 4.88 was right for 31's:
31 = 4.88
33 = 5.29
35 = 5.71
37+ = fuhgeddaboudit
Now, since that doesn't account for the extra weight/drag of the larger tires, or the power drop from going to a 4 cyl, I would say those are the MINIMUM, and you may want to step down (up numerically) one step from that, which will raise your RPM about 250 on the highway. You want to be at 3000 - 3500 RPM at your highway speed. That will result in the lowest throttle opening and the best gas mileage, while providing enough throttle response to not have to downshift on every roll in the road, and a low enough 1st gear to get good clutch life.
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
calderp
Jul 27, 2015 09:58 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
redghost.308
California SoCal
Jul 16, 2015 07:46 AM
