Sponsored by: CARiD
vibration
Old Nov 11, 2011 | 04:48 PM
rcm's Avatar
rcm
vibration
Ok in 4th gear running 40-50 mph i have a vibration.
u joints do have a little play and really greased them 200 miles ago.I slip the tranny in neutral and alot of it goes away.Just seems under load and once in 5th doing 55 and up it feels fine.Any ideas before a u joint replacement?
Old Nov 11, 2011 | 05:18 PM
rbmoomba's Avatar
I'd say replace them. Good news if the vibration was not in 4th gear but occurred in any other gear it could be the input shaft on the transmission. I just went through that fiasco. Good luck
Old Nov 11, 2011 | 05:29 PM
rcm's Avatar
rcm
It doesnt seem to do it any other time and once i shift to 5th and get to 55 it quits.Did your input shaft have alot of play?
Old Nov 17, 2011 | 02:08 PM
rcm's Avatar
rcm
just an update.Pulled rear drive shaft,front u joint bearing surface where chaffed.
noticed a leak.Pulled the splined hub off of transfer and the teeth are worn and leaking
past the grooves.I guess that would cause a vibration.Got another one coming.
The output shaft looked good...
hiluxinargentina
Sep 30, 2015 05:51 PM
JPV
Sep 28, 2015 03:15 PM
Odin
Sep 26, 2015 06:56 PM
4Xtruck
16
Sep 24, 2015 09:38 AM
tinigunner11
Aug 14, 2015 01:19 PM
