Sponsored by: CARiD
Valve cover gasket on, now it stalls ?? =/
Old Mar 26, 2011 | 05:42 PM
Jim_M's Avatar
Discovered the source of an oil leak at the rear of my valve cover. Replaced gasket, leak gone. Good.
Started truck and now it idles so slow it stalls. I'm guessing (definitely) that the throttle cable is not set correctly now that I removed and re-installed its bracket at the rear of the valve cover. Guessing for sure since it's the only carburetor related device touched during the gasket replacement. Ran out of sunlight and thought of posting here. Your ideas and advice is very much appreciated. Thanks!
Jim
Old Mar 26, 2011 | 05:55 PM
annoyingrob's Avatar
Make sure you didn't knock out one of the half-moon seals on the head too. Thre's the one at the very front, and one at the very back that sit under the valve cover.
Sometimes you can knock the back one out when you put the valve cover on.
Old Mar 26, 2011 | 06:16 PM
Jim_M's Avatar
Thanks. Not sure I follow. I replaced both half moon seals when I replaced the valve cover gasket today. I can see the front one and feel the rear one. So..I hope I'm good to go there.
smthwsn357
May 1, 2024 07:28 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
Sep 4, 2015 09:27 AM
irritech
Jul 27, 2015 05:15 PM
87blyota
Jul 10, 2015 04:31 AM
